7 members (IcePack, John V6, Chris Cosher, Gonze, Alan Patterson, Ian Wegg, DickJ), 357 guests, and 90 robots.
Topics49,847
Posts837,391
DazMog, The Impaler, tlchzj79
Page 8 of 13 1 2 6 7 8 9 10 12 13
Q
Q
Great point about the electronic memory loss.will it happen if we disconnect the battery?
how can we update the ecu if needed at home?
I disconnect the battery regularly as I've not got power in the garage for a battery conditioner.
On reconnection it's fine, no loss of trip or mileage data but the clock does need to be reset.
Red Leader drive
The fuel sender circuit is not powered when the ignition is off. There fore, I did not disconnect the battery.
Roland
Recommend Eurospares too - v good service:)
No need to disconnect battery - but take precautions - ignition off - and disconnect positive first /connect neg/earth first when fitting etc - usual good practice stuff:))
Neil
Did you mean Europaspares rather than Eurospares? Two very different companies.
Er, no. Negative/earth should be disconnected first.
Yes Europaspares!sorry:((
Yes Neg/earth disconnected first - oops - had a bad day!! ooo
Neil
Well, it could have been a far worse day if you had followed your own advice!
mad
Neil
Q
Q
Just arrived fun installation time
[url=[URL=http://s1349.photobucket.com/user/Q8morgan/media/image_zpsab555e3b.jpg.html][/url]][/url]
