8 members (TalkMorgan, nick w, BertL, Plus Four Guy, RedThree, Strathaven, sprinty, mph), 268 guests, and 54 robots.
Topics49,846
Posts837,380
Page 3 of 13 1 2 3 4 5 12 13
Having looked at the kit and the way it goes together, the most difficult part would appear to be unscrewing the upper ball joint and installing the upper steering arm. The rest of it would go together quickly and the only re-alignment of the steering would be re-setting the toe-in. You could do this in your garage if you were careful and had some scrap plywood to make an alignment rack.
I am more in agreement with 2 hours of shop time being needed vs the 8 hours I was quoted. I also think the track rod extensions need to be black so as to not be so obtrusive.
Was the dealer that quoted you 8 hours in California or in Scottsdale?
Past The City Limits
California but I miss-typed, it was 6 hours. Scottsdale has not received any hardware yet.
Avoid Cal
2005 Roadster
2013 M3W
MOG South
Originally Posted By HJP
I think there are slight variations in the kits due to the different racks fitted at various times .
I've just enquired about getting mine done and there are (at least) 2 versions depending on the steering rack.
Apparently some have a hole in the middle (when viewed from above) and some don't. Checking mine tonight and then getting it booked in spend
Red Leader drive
Q
Q
Show us the pic of the version you have & what to look for..because you cant garuntee what type of version you have on only the build year or month..for example mine is a october build 2013. & the compensator i have doesnt have the hole in the casing
Originally Posted By Q8morgan
Show us the pic of the version you have & what to look for..because you cant guarantee what type of version you have on only the build year or month..for example mine is a october build 2013. & the compensator i have doesnt have the hole in the casing
The hole is in the steering rack, not in the compensator.
Nô Peter there is an upgrade with an hole under the compensator
Mine was upgraded
HJP Offline
There are also some steering racks with holes in the top and some without !
Hugh
Mine was upgraded
Ah, I see. Well, I don't really...
Where is this hole in the compensator casing? And what is its purpose?
Perhaps Chris Pollitt, the Assistant Editor of MOG Magazine, who popped up on this forum and then seems to have disappeared, could issue a bulletin about the various holes that were not in the early 3 Wheeler, and those that have been fitted (if one can fit a hole) and what they are there for.
