1 members (+8Rich), 262 guests, and 42 robots.
+8Rich 65
Adam12 62
John V6 59
9,215 Registered Users
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,365
Posts813,356
Members9,215
Rbt Aero8, Salmon, stevends
JMS 4/4 Offline OP
Can I charge/condition my battery by simply plugging the battery charger in to the 12v socket in the glovebox of my 2008 Plus4? Is it safe to do so? "Currently" charging with direct croc clips onto battery but a bit of a faff accessing battery via hatch behind passenger seat.
Check that the 12v socket is always live.
If it is it can be used for charging your battery.
I did that on my 2011 Plus 4.
However I found the connection to be a bit intermittent, so connected a separate fused connection to the battery and to a socket on the shelf behind the seats to make the connection easy to access. I use a CTEK charger and cables.
Ian
Should be safe if the socket is a cigarette lighter size and rated at the current of one. I'd not connect an old fashioned battery charger that way, but the kind of charger sold as a conditioner does not charge at such a high current.
Do you have a voltmeter? You need to check the socket is always live, and not on position 1 of the ignition key.
Yes subject to it being always live. Also fusing the system is a very smart idea.
JMS 4/4 Offline OP
Thanks all for prompt replies, first time I've tried the forum.
Checked socket and it is live, even when ignition key is out. There is also a lighter fitted in the socket so rating should be ok.
I have borrowed a CTEK charger from a friend, seems very good so will probably get one c/w plug for 12v socket.
If I put in a fused connection what size fuse should I use?
Not seen the wiring diagram for a 2008 car, but the socket itself ought be fused at a fairly high rating.
If the battery charger does not have one, easiest thing to do is put an in-line fuse and holder in the lead from it to the car. The book of words on the charger ought to give maximum output, and the fuse needs to be rated a bit higher. Example, if charger supplies up to 3 amps, put a 5 amp fuse in.
Yes, no problem on a 2008 Plus 4. I do this every winter and when the car is left in the garage for a long period.
Harald
I do this regularly with my 2003 4/4. Works a treat.
Roger
South Wales
2003 4/4 (Meg)
Connaught Green
This has been discussed a number of times. The answer is yes, and the feed for the light socket is fused. I charge my 2005 4/4 this way using a Cetek charger.
Nigel
I did it for years like that but my second Mog had the cigar lighter on the wrong side so I set up a separate fused feed
2025 MG ZS EV aka Trigger
