9 members (Graham, G4FUJ, cerealsurfer, DCH, High Hamster, Montegue, JamesS, MartO, Joske Vermeule, TeddyAds),
346
62
Topics49,860
Posts837,522
Posts: 206 |
The cooling kit is brilliant! No more troubles in the traffic!
Posts: 1,338 |
Is it an easy installation? Alot of holes/wiring behind the engine..do they need to be lengthened?
Posts: 206 |
My dealer did it for the factory fixed price, so i had no troubles with it.
Posts: 1,338 |
Ez oil drain Part #ez-107 Thread size 12mm-1.75 Works like a charm [url=[URL=http://s1349.photobucket.com/user/Q8morgan/media/image_zpsf15d4fa6.jpg.html]  [/url]][/url]
Posts: 1,338 |
But i couldnt center the valve straight,the level is on the left a bit
Posts: 1,338 |
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
So the thread mystery is solved! Looks good.
Richard 1976 4/4 4 Seater
Posts: 1,338 |
Haha yes solved at last 12mm 1.75
Posts: 1,338 |
I really recommend the ez oil drain valve.first i drained the oil tank and afterwards i removed the oil filter thinking i will flush much more oil out,but that wasn't the case.of course there is going to be some oil in the engine but not as much as you suspect. [url=[URL=http://s1349.photobucket.com/user/Q8morgan/media/image_zps95bca22c.jpg.html]  [/url]][/url]
Posts: 1,338 |
I used the factory washer between the oil tank & oil drain valve & now its centered & looks much better [url=[URL=http://s1349.photobucket.com/user/Q8morgan/media/image_zps06d6f03a.jpg.html]  [/url]][/url]
