7 members (B3MOG, hillclimber, tezzer, JohnHarris, Ian Wegg, DCH, Bitsobrits), 343 guests, and 82 robots.
Topics49,848
Posts837,405
DazMog, The Impaler, tlchzj79
#186787 17/03/14 06:45 AM
Dreiradschubser
Dreiradschubser
Some pictures:
Waldemar #186793 17/03/14 06:55 AM
PJB Offline
And the gear ratio is? Breath baited. PJB
Waldemar #186794 17/03/14 06:57 AM
The gears look very similar to those used in the Moto Guzzi bevel drives. They seldom give any problems but, to be fair, they don't have to cope with the tremendous torque pulses of the SS motor.
Waldemar #186798 17/03/14 07:18 AM
Great to see the internals - thanks v much for posting - very interesting! scared
Neil
Waldemar #186799 17/03/14 07:18 AM
Interesting - thanks for sharing.
Waldemar #186804 17/03/14 07:41 AM
So which bit makes all the noise? ooo
Graeme: 2011 +4
Waldemar #186806 17/03/14 08:03 AM
Hi this is probably a silly question,why did you strip the bevel box?
The pics are great thank you for sharing them.
Regards David
,,BSA Goldstar,Honda CB1100R. Jaguar FTypeS Porsche Cayman S
Waldemar #186813 17/03/14 08:59 AM
On a rough count it looks to be about 32/16 - so 2:1.
Very interesting!
Waldemar #186814 17/03/14 09:11 AM
I thought that the bevel gearbox gears are straight cut, hence all the noise. This looks like helical gears to me, a crown wheel and pinion, like mosts diffs. They ususally make noises because of incorrect preload or worn bearings. Nice to see the insides. Also be interested in the reason for the strip of the gearbox.
planenut #186820 17/03/14 10:12 AM
I had also understood that the bevel bow used straight cut gears. The NVH mod make much more sense with helically cut gears. The splines on the input/pinion shaft don't look to be in very good shape though.
Philip.
