4 members (B&C Morgan, BLUE+4, John Winn, Barkbark), 267 guests, and 57 robots.
+8Rich 82
Topics49,859
Posts837,500
Jonny72
Page 1 of 6 1 2 3 4 5 6
Crowbar Offline OP
Hello gents...
So I have noticed a worsening rattle at low RPM (2000-2500) that seems to emanate from behind the rear passenger seat (LHD car). It occurs in both forward and reverse gears
The rattle disappears when the clutch is depressed, so I suspect something in the drive train...
It's also gone when I'm over 3000 RPM...
It almost seems as if something in the drive train is loose (bevel box mount?) and a harmonic is set up at low RPM's
I'm attaching a link below to a video in which you can clearly hear what I'm talking about.
[video:google]https://drive.google.com/file/d/0B9cgseXkIVq4ODhGYm9FQjBQVzZHeXUtbkN0RmJqVFE5RnNv/edit?usp=sharing[/video]
I'm planning to pull the seat back and the center console to try to localize the rattle this weekend, but any suggestions are appreciated!
1965 Plus 4
2008 997 Turbo Cab
1981 Alfa Spider
1954 Austin Healey 100 (SOLD)
2013 M3W (SOLD)
thinking That's new, can't wait to find out what that is ... listening
thumbs cheers
2013 M3W # 793
'Mosquito'
Crowbar Offline OP
Trying to fettle this myself and spare the cost of shipping the car to Arizona...
Before I pull the seats, I may remove the boot floor and have my wife drive me around the block, while I sit in the passengers seat and stick my head in the open boot and listen...the neighbors already think I'm nuts, this will confirm it...
1965 Plus 4
2008 997 Turbo Cab
1981 Alfa Spider
2013 M3W (SOLD)
Sound look like compensator.
This strongly resembles the compensator or the drive shaft flywheel.
Generally noise resonates throughout the metal transmission.
How many miles have you.
Don't forget to get someone to video that test drive! It will be a Youtube record breaker!
Oct 13 build 4/4
Agreed - this sounds like typical Compensator failure - or at least starting to fail - its a horrible noise :(((( frown2
Neil
sorry to hear about the noise. it's also helpful to pull the transmission tunnel cover and driveshaft cover. by doing this you can drive around with it fully exposed and see if you can heard the sounds more directly as others have mentioned these sounds have a sneaky way of sounding like the are coming from one area but in fact another area far away.
blake
sfmorgan.tumblr.com
Have to agree with M3BOY, my compensator started off like that and then got much worse.
