Topics49,846
Posts837,382
Posts: 25 |
Does anyone know why the turn signal switch is on the left for RHD vehicles but on the right for LHD vehicles?
Posts: 64 |
Posts: 1,075 |
Does anyone know why the turn signal switch is on the left for RHD vehicles but on the right for LHD vehicles? I wouldn't bet a pay check on this, but the turn signal lever is about as long as the out edge of the steering wheel. If it were on the left side for a LHD M3W, it would probably hit the cowl as it sweeps down the left side from the dash. Not enough room to use it safely I would guess.
Dan
Posts: 1,664 |
Does anyone know why the turn signal switch is on the left for RHD vehicles but on the right for LHD vehicles? I wouldn't bet a pay check on this, but the turn signal lever is about as long as the out edge of the steering wheel. If it were on the left side for a LHD M3W, it would probably hit the cowl as it sweeps down the left side from the dash. Not enough room to use it safely I would guess. This. To avoid contact with the body.
Charlie, Former Editor Morgan Owners Group - Great Lakes
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
I have a vague memory it was done in the 70's or 80's to standardise control layout. Prior to that each manufacturer made up their own mind.
I think indicator on the right for LHD was favored by the USA and Europe, visa versa for Japan and so UK ended up with left hand indicators.
Someone with a better memory than mine might be able to shed more light...
Red Leader
Posts: 1,075 |
All turn signal levers in cars in the US are on the left.
Can't see why someone here would think the right side of the wheel is better.
I just don't see the room on the left side for it from the pictures I've seen.
Dan
Posts: 1,947 |
Chris I think you are correct. So far as I'm aware Hyundai/Kia were last to fall into line.
Tim.
