6 members (RichardV6, cerealsurfer, +8Rich, Guten, Alan Patterson, JohnHarris), 204 guests, and 90 robots.
+8Rich 73
DaveW 52
Topics49,867
Posts837,619
Moggo
CBY Offline OP
Have you change your radiator on a PLUS 4?
The clearance is very narrow, what is the procedure in order to extract it?
Regards
2005 PLUS 4
...from underneath?
I'm pretty sure someone has done this and there is a thread somewhere on the site.
I have just changed mine on a 2009 Roaster, very easy when you follow the instructions, send me your e-mail and I will send you pictures before and after and printed instructions
Morgan 2009 Roadster Rolls Royce Lush Green 3.0 V6
Audi A4 Advant (some blue colour not botherd)
CBY Offline OP
Not found. Found on an other french forum for a 4/4, by underneath, but on a PLUS 4 the radiator seems larger. If somebody did it and can provide lessons learned.
Just sent my email to STUMOG.
Regards
2005 PLUS 4
Try here.
U
TM Photographer of 2008
U
When the radiator in my 2005 Plus 4 was replaced the bonnet and cowl were removed, so I assume it was replaced from above.
Ken
CBY, I replaced mine with a larger Mulfab radiator. It went upwards with a bit of a wiggle but was not difficult to do.
Radiator removed and re-cored on 81 4/4, pulled again for engine out /clutch replacement. Also pulled radiator on 71 Plus 8. I have always done this from the top, removing the cowl. A bit fiddly but doable. Once the cowl is off, it's not hard.
It may be possible to it from the bottom but I have never tried.
Mark
1934 SS MX4
1938 Series 1 DHC
1951 Plus 4
2005 Roadster
CBY Offline OP
Thank you all for your answers,
it seems than the cowl must be off for the PLUS 4.
Somes do it underneath, I guess in the case of 4/4 which radiator is smaller; I phoned to a 4/4 friend who measures it : 35x35x5 cm (alu).
After there is the roadster where it seems to have much room between the motor and the radiator : 3 cylinder length vs 4 for the 2L Duratec.
To meabh : is it a PLUS 4? Do you take out the fan first?
Regards
2005 PLUS 4
