6 members (jbk, Chris Cosher, Graham, G4FUJ, Morganmike, ScotiaSteve, TBM),
311
89
Topics49,859
Posts837,481
Posts: 5,654 Likes: 4
Posts: 5,654 Likes: 4 |
I have just had my new in tank electric fuel pump replaced and the car is now running well. Looking at the old pump the live terminal had overheated and showed signs of burn out. At the bottom of the pump there is a fine gauze strainer 60mm diameter. This strainer should prevent particles from passing through the pump.The filter therefore is only there for the " final clean" Sounds like a faulty connection was the root cause then.
Martin (Deano)
Posts: 25 |
More possible is a design fault.I am told that on a Mondeo the fuel pump is well out of the way of any water.On a Morgan this is not the case. The fuel pump casing has a shallow trough where the electrical plug connects.It is possible when driving in rain that this trough fills with water which somehow burns out not only the pump live terminal of the plug but also the terminal in the pump. The pump plug is made by AMP (German )sealed connectors ( on-line cat. page 60 ) and are available from TE Connectivity in England.The problem is that to replace the plug properly one needs the correct ribbed wire inserts and expensive special crimping equipment. I purchased a s/h Mondeo plug from the breakers for £4 and soldered and heat shrinked the wires to the harness. To prevent the same thing happening again I have duck taped around the pump.
