Topics49,901
Posts838,042
Posts: 3 |
What is the best grease for the front suspension pillars ? Has anyone used Molybdenum Bisulphide (molyslip) grease additive to reduce friction ?
Posts: 3,643 |
I use Comma CV Lith-Moly grease, from Halford, does the job.
Posts: 3,383 Likes: 14
Posts: 3,383 Likes: 14 |
I have always used Castrol LMS, used it for years on almost everything chassis related on cars. This is lifted from BP's website....Not that easy to find these days but worth a Google or eBay search. I 'think' LMX is todays replacement but that needs checking out. I buy/bought LMS 10 tubs a time so have not bought any for ages....note to self down to 2 tubs!
Description An NLGI 2 consistency lithium soap based, extreme pressure [EP] grease incorporating 3% molybdenum disulphide (MoS2) and a highly effective combination of load carrying, oxidation inhibiting and anti-rust additives. This product is water resistant and oxidation inhibitors and anti-corrosion additives ensure a long service life and a high level of corrosion protection. The inclusion of molybdenum disulphide makes this grease particularly suitable for applications where fretting, corrosion and wear are a problem. It is often used to lubricate automotive ball-joints to reduce noise, wear and make steering easier, as well as CV-Joints to reduce wear and noise.
Applications Energrease LMS-EP 23 is suitable for most of the grease lubrication tasks of industrial, mining and automotive sectors. It is especially suitable for applications where high loads or sliding contact surfaces are involved. It was developed primarily as a rationalisation grade to reduce the grease inventory of large construction or mining companies.Common applications include, grease lubricated chassis points on cars, trucks, buses, earthmoving agricultural and mining equipment. It is also used on semi-trailer fifth wheels [turntables] and other similar slow sliding-contact moving surfaces
Main Benefits Extreme pressure load carrying capability - Corrosion resistance - Resistant to the effects of vibration - Resistance to wash-off by water - Good shear-stability - Oxidation resistant
Posts: 27,839 Likes: 764
Posts: 27,839 Likes: 764 |
Castrol CL as it is water reistant
Posts: 986 |
CV moly for me to. You can get it from Amazon.
Andy
Laser red 4/4 Red Classic Mini Cooper Sport Audi TT 2.0 TFSI Quatro
