9 members (+8Rich, SEG, rossocorsa, bmgermany, MartO, JohnHarris, flyfisher, High Hamster, John Winn), 230 guests, and 32 robots.
+8Rich 96
John V6 51
Topics49,901
Posts838,047
#195185 30/04/14 12:02 PM
Forest Offline OP
What is the best grease for the front suspension pillars ? Has anyone used Molybdenum Bisulphide (molyslip) grease additive to reduce friction ?
I use Comma CV Lith-Moly grease, from Halford, does the job.
Ian
I have always used Castrol LMS, used it for years on almost everything chassis related on cars. This is lifted from BP's website....Not that easy to find these days but worth a Google or eBay search. I 'think' LMX is todays replacement but that needs checking out. I buy/bought LMS 10 tubs a time so have not bought any for ages....note to self down to 2 tubs!
Description
An NLGI 2 consistency lithium soap based, extreme
pressure [EP] grease incorporating 3% molybdenum
disulphide (MoS2) and a highly effective combination
of load carrying, oxidation inhibiting and anti-rust
additives.
This product is water resistant and oxidation
inhibitors and anti-corrosion additives ensure a long
service life and a high level of corrosion protection. The inclusion of molybdenum disulphide makes this
grease particularly suitable for applications where
fretting, corrosion and wear are a problem.
It is often used to lubricate automotive ball-joints to
reduce noise, wear and make steering easier, as
well as CV-Joints to reduce wear and noise.
Applications
Energrease LMS-EP 23 is suitable for most of the
grease lubrication tasks of industrial, mining and
automotive sectors. It is especially suitable for
applications where high loads or sliding contact
surfaces are involved. It was developed primarily as
a rationalisation grade to reduce the grease
inventory of large construction or mining companies.Common applications include, grease lubricated
chassis points on cars, trucks, buses, earthmoving
agricultural and mining equipment.
It is also used on semi-trailer fifth wheels [turntables]
and other similar slow sliding-contact moving
surfaces
Main Benefits
Extreme pressure load carrying capability
- Corrosion resistance
- Resistant to the effects of vibration
- Resistance to wash-off by water
- Good shear-stability
- Oxidation resistant
BR Colin
Castrol CL as it is water reistant
CV moly for me to. You can get it from Amazon.
Andy
Laser red 4/4
Red Classic Mini Cooper Sport
Audi TT 2.0 TFSI Quatro
