7 members (MJF, KennyW, B&C Morgan, Robbie, Mike D, verysideways, Image), 270 guests, and 33 robots.
+8Rich 94
John V6 50
Posts837,996
rockabilly john
#196171 05/05/14 07:57 AM
I
inde101 Offline OP
I
Hi there
Just been playing with the idea of putting a side pipe on my 1.8 duratec 4/4.
Anyone any thoughts or ideas if it would be any good?
Also looking at changing the exhaust manifold and cat. I have ones from a +4 duratec and wondering if they would work. The manifold especially looks like it was thought about a bit more.
Many thanks
Gaz
Gaz
I am a fan of the side exit exhaust and it fairly easy to do on the classic chassis cars because you don't have to modify the wings. So my advice is go for it.
Martin (Deano)
There you go!
Side exhaust
but you do end up having to clean one ear more often than the other (been there ,done that)
Aero side exhausts look great, but not seeing any aesthetic benefit on a classic? - I know beauty is in the eye of the beholder and all that.
2016 Carmine Red 991.2 C4S
its all about the sound listening
Martin (Deano)
I
inde101 Offline OP
I
Thanks guys
I had the box off a few times playing so it is pretty easy to do.
Does it make the smaller engines sound better or is it just loud.
Chris : on the other had it might balance things out as SWMBO sits on the other side
Gaz
I first did this on a Kent engined 4/4 and it did sound deeper in tone - nice not noisey
I have side pipes which came fitted on my '97 3.9 plus 8. Although I prefer the look of two pipes out of the back, I do think there is one advantage of side pipes: less risk of grounding on humps and bumps and steep gradients. In addition to which the sound is more immediate (ok, louder). On the other hand I get asphyxiated when I start up inside the garage.
1997 +8
Originally Posted By inde101
Hi there
Many thanks
Gaz
Hi Gaz
Have a look here. https://www.flickr.com/photos/116051653@N07/12250686393/in/set-72157640417787664
Side exit fitted to a 4/4 Sport on standard down pipes and Cat no ECU changes checked on the dyno to insure safe running 134bhp... from stock checked on dyno 114bhp.
From a Racing re-packable Morgan V8 with Intake pipe to suit my down pipe. Sounds good too!
Cain
Cain
Wolf Cafe Racer
4/4 Sport
