Morgan Aero 8
0 members (), 213 guests, and 46 robots.
+8Rich 86
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,360
Christoph
#196892 08/05/14 05:57 PM
Having always regretted selling our Aero 8, Stephen & I are finally back in the Morgan fold with our lovely Supersports. I'm sure some of you will recognise the car wink
Absolutely chuffed to bits with it!
Two minor issues though: the wind noise at 70 is horrendous - it sounds like it is coming from the front middle bit of the root. Is this normal? Also, the rear left round light has condensation in it. Is there an easy way to remove it?
Don't know about the roof, but the only way to get rid of condensation is to remove the lens. Or alternatively go in from the bulb side with a lint free cloth.
PS Welcome back!
Aha, so that's where the car went! smile
Welcome back! thumbs
Enjoy!
Wind noise could just be adjustment of the roof panels.
Martin (Deano)
deano #196981 09/05/14 05:44 AM
Looks great, have fun!
Roof panel fitting guide - will follow next week once scanned BUT fitting:
1) Start on the left panel (obviously) and mount it by putting the outside edge in first, then gently pushing in until the inside one is in. The rubber seal should extend outwards and run parrellel to the top of the windscreen.
2) Close the panel on all 4 clips
3) Repeat step 1 for the right panel - but you join the 2 panels make sure the rubber from the left panel stays parrellel to the top of the windscreen and sits neatly under the right panel. You may need to use your finger to guide it in
4) Close the panel on all 4 clips
Mine still needs a slight adjustment on the clips, however a noisey 70mph cruise became quieter at 85mph with the roof fitted as above.
2010 Aero Supersport | 2017 VW Multivan | 1996 BMW M3 Evo
afr Offline
Good timing with summer around the corner, looks great!
Fabulous car, Congrats!
Mark
1934 SS MX4
1938 Series 1 DHC
1951 Plus 4
2005 Roadster
Thanks for the notes on the roof - it was easier than expected.
Does anyone know how to remove the round rear lights? The manual suggests turning something anti-clockwise but isn't specific and I don't want to damage the car.
Current: Aero SuperSports
Previous: Aero 8 S3
Want: Aero 8 GTN
