9 members (TBM, SteveT, MOG42, CooperMan, TeddyAds, Aeromax51, GrumpyPa, sprinty, MJF),
234
45
Topics49,843
Posts837,348
Posts: 124 |
Having always regretted selling our Aero 8, Stephen & I are finally back in the Morgan fold with our lovely Supersports. I'm sure some of you will recognise the car Absolutely chuffed to bits with it! Two minor issues though: the wind noise at 70 is horrendous - it sounds like it is coming from the front middle bit of the root. Is this normal? Also, the rear left round light has condensation in it. Is there an easy way to remove it?
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
Don't know about the roof, but the only way to get rid of condensation is to remove the lens. Or alternatively go in from the bulb side with a lint free cloth.
PS Welcome back!
Posts: 28,892 Likes: 350
Posts: 28,892 Likes: 350 |
Aha, so that's where the car went!  Welcome back!
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Richard 1976 4/4 4 Seater
Posts: 5,654 Likes: 4
Posts: 5,654 Likes: 4 |
Wind noise could just be adjustment of the roof panels.
Martin (Deano)
Posts: 519 |
Posts: 861 |
Roof panel fitting guide - will follow next week once scanned BUT fitting:
1) Start on the left panel (obviously) and mount it by putting the outside edge in first, then gently pushing in until the inside one is in. The rubber seal should extend outwards and run parrellel to the top of the windscreen.
2) Close the panel on all 4 clips
3) Repeat step 1 for the right panel - but you join the 2 panels make sure the rubber from the left panel stays parrellel to the top of the windscreen and sits neatly under the right panel. You may need to use your finger to guide it in
4) Close the panel on all 4 clips
Mine still needs a slight adjustment on the clips, however a noisey 70mph cruise became quieter at 85mph with the roof fitted as above.
2010 Aero Supersport | 2017 VW Multivan | 1996 BMW M3 Evo
Posts: 42 |
Good timing with summer around the corner, looks great!
Posts: 1,500 Likes: 2
Posts: 1,500 Likes: 2 |
Mark
1934 SS MX4 1938 Series 1 DHC 1951 Plus 4 2005 Roadster
Posts: 123 |
Thanks for the notes on the roof - it was easier than expected.
Does anyone know how to remove the round rear lights? The manual suggests turning something anti-clockwise but isn't specific and I don't want to damage the car.
Current: Aero SuperSports Previous: Aero 8 S3 Want: Aero 8 GTN
