7 members (RichardV6, Lordofthewings, Julian BB, sbarracl, JohnHarris, docock, aerotaff), 315 guests, and 80 robots.
+8Rich 86
Sagging Hood
Topics49,854
Posts837,451
Page 3 of 4 1 2 3 4
The Seeker #199807 22/05/14 04:29 AM
soapbox UPDATE soapbox UPDATE soapbox UPDATE soapbox UPDATE soapbox UPDATE soapbox UPDATE soapbox UPDATE soapbox UPDATE soapbox
waiting Got in the que 04AUG12, ordered luggage rack as well. Delivered 20JUN13, sans ordered luggage rack. confused2
party Mosquito celebrated her 1st birthday, 17MAY14. roses
mail Dealer emailed 20MAY14, ordered luggage rack has arrived ! happy3
That is all .... viking
thumbs cheers
2013 M3W # 793
'Mosquito'
The Seeker #199808 22/05/14 05:25 AM
joy
Chrome or Black?
woohoo
Past The City Limits
The Seeker #200013 23/05/14 12:48 AM
Chrome. Got the chrome package, so ...
My dealer says it's the first he's ever seen. Since it's been a year wait, I wouldn't even hazard a quess on how long for a black one. tumbleweed
thumbs cheers
2013 M3W # 793
'Mosquito'
The Seeker #200072 23/05/14 02:55 PM
Z
Z
I ordered a black one and had it in a week. Instead of drilling, I used aluminum bar mounts as others have done instead of drilling the roll bars.
https://www.pegasusautoracing.com/productselection.asp?Product=2035-320
I had to open up the holes to 1/2" for the luggage rack pins to fit.
Installing the rack gave me something to do while waiting on my Empire bits to come back from anodizing.
Z
The Seeker #200073 23/05/14 02:59 PM
Such a neat job- better than drilling!!
Like the coated Empire parts too - well done!!
Neil
The Seeker #200077 23/05/14 03:35 PM
SBM Offline
I agree, a very neat job.
If only someone would engineer a hinged mechanism, it would be even better. Having to take the rack off to open the boot is a pain..
The Seeker #200079 23/05/14 04:08 PM
Very nicely done.
Also like your new Indian.
The Seeker #200088 23/05/14 05:27 PM
I Wonder if your bar mount supplier would ship to the UK as I have searched high and low to find any over here and there is none to be had.
I think a luggage rack would be a worthwhile addition prior to Le Mans 2014.
The Seeker #200138 23/05/14 09:02 PM
Zackybilly1,
Brilliant ! idea
I've seen this set up on FB, but with two clamps per side. Do you feel that one each side is sufficient ? Have you carried a load on it yet ? Like the Indian, as well !
Tally Ho !
The Seeker
thumbs cheers
2013 M3W # 793
'Mosquito'
The Seeker #200158 23/05/14 10:18 PM
Z
Z
I like the Indian, too. 119 ft./lbs. of torque @ 3k rpms. But make no mistake...the Wing (Goldwing) is still King.
Facebook is where I found the link for the clamp.
My observation is that the fellow that had two pair of clamps (which I purchased two pair just in case) did so in order for his length to work out on where the hair-pin goes through the +/- 3/8" rod of the rack securing the front end.
Once you hold the clamps in your hands, you'll know they are well made. Each half of the clamp is such a good fit on the roll-bar, that with the clamping bolt loose, it's still difficult to slide them up or down the roll-bar. The clamp is designed in such a way that the bolt adds linear clamping force but to spread the halves, the bolt goes into shear which would be a considerable amount. To be a simple item, you can tell some thought when in to them.
Where the clamp mounts, its not vertical to planet earth so it is slightly cocked when mounted. That is the reason for opening up the hole to 1/2" as the pegs on the rack are geared for a vertical slip fit. I took the "top-hat" plastic bushing that came with the rack and shortened them to the thickness of the clamp. When I install the rack, I slip a short piece of rubber hose to take up the length difference. I trimmed them to where the rubber has to be slightly compressed to install the hair-pin. This keeps the rack, as well as, the hair-pin from adding to the other usual rattles of the car.
I just installed the rack a few days ago and have not had a chance to use it with a load but have no doubts or I'd still be working on it. Being a motorcycle guy, I am used to strapping things down and what to expect out of a rack. I've lived out of tour-packs on motorcycles over the years so don't see much difference here including the water-proofing aspect.
Yes, a hinged model would be handy but I don't get much service often out of the boot anyway. If I have a rear flat, removing the rack is the least of my worries. That and I already have more projects than I should.
I suspect on my trips, a fair amount of my "stuff" will be in the passenger side. I'm not taking any women on a trip in this car and more than likely, the reason for the trip will be to get away from a woman.
Z
Page 3 of 4 1 2 3 4
