7 members (MJF, bmgermany, Jon G4LJW, Image, Aeromax51, TalkMorgan, RichardV6),
273
Posts838,002
Posts: 17 |
Hello all, I've some little scratches on my rear plexiglass window on my +4 2008. washing it carefully doesn't make difference, they remain. So does anybody knows how to make them disappear properly without damaging the plexiglass ?
Anybody knows RENOVO product ? Seem that this product delete small scratches but...
At the other hand, which product to clean wire wheel with chrome ? Best regards.
Retrobate Has a lot to Say!
Posts: 1,103 |
A quick 'Google' found this http://www.morethanpolish.com/hindsight.asp If you do try it, please report back - my 2007 +4 has some marks as well - but not too serious yet.
TM Photographer of 2011 Talk Morgan Regular
Posts: 963 |
I always had good results with the "original BMW Convertible rear window cleaner". It comes in a 75 ml tube with the part number: 81 22 9 407 665.
I never used it on the Morgan, but it worked fine on my (and many other owner's) Fiat barchetta.
Salut, Ivo
 1998 +8 (permanently out of service  )
Posts: 141 |
Ronovo's the stuff you need, brings up plastic windows crystal clear. Not cheap concidering the size of the bottle, but you only use it sparingly.
rgds Nick....just waiting for the sunshine...
Posts: 849 Likes: 2
TM Photographer of 2008 Talk Morgan Regular
Posts: 849 Likes: 2 |
There's a product called Polywatch which is used to remove scratches from plastic watch-glass. I have been impressed with it when used for that purpose. You could give it a try. I paid £5 for a tube at a Jewellers but I've also seen it on eBay.
As your hood is new you don't need a product that will restore the clarity of the rear window. If you do need to remove the haziness autosol chrome cleaner, Cif houshold cleaner or Brasso does the trick.
Ken
Posts: 17 |
Thank you all for your advices, I will keep you information about result as soon as possible. Best regards.
Posts: 141 |
Quarre,
be very careful with the products you use as some could react with the thin plastic windows, clouding them or making them brittle....a costly mistake.
Please use a product designed for the job and Ronovo does polish out scratches.
cheers and good luck.
