4 members (Krossek, jbk, Rog G, Julian BB), 291 guests, and 51 robots.
+8Rich 95
John V6 52
Posts838,013
rockabilly john
Q
quarre Offline OP
Q
Hello all,
I've some little scratches on my rear plexiglass
window on my +4 2008.
washing it carefully doesn't make difference, they
remain.
So does anybody knows how to make them disappear properly without damaging the plexiglass ?
Anybody knows RENOVO product ?
Seem that this product delete small scratches but...
At the other hand, which product to clean wire wheel with chrome ?
Best regards.
Retrobate
Retrobate
A quick 'Google' found this
http://www.morethanpolish.com/hindsight.asp
If you do try it, please report back - my 2007 +4 has some marks as well - but not too serious yet.
Ivo Offline
TM Photographer of 2011
I always had good results with the "original BMW Convertible rear window cleaner".
It comes in a 75 ml tube with the part number: 81 22 9 407 665.
I never used it on the Morgan, but it worked fine on my (and many other owner's) Fiat barchetta.
Salut,
Ivo
sunny
1998 +8 (permanently out of service frown )
NJR Offline
Ronovo's the stuff you need, brings up plastic windows crystal clear. Not cheap concidering the size of the bottle, but you only use it sparingly.
rgds
Nick....just waiting for the sunshine...
U
TM Photographer of 2008
U
There's a product called Polywatch which is used to remove scratches from plastic watch-glass. I have been impressed with it when used for that purpose. You could give it a try. I paid £5 for a tube at a Jewellers but I've also seen it on eBay.
As your hood is new you don't need a product that will restore the clarity of the rear window. If you do need to remove the haziness autosol chrome cleaner, Cif houshold cleaner or Brasso does the trick.
Ken
Q
quarre Offline OP
Q
Thank you all for your advices, I will keep you information
about result as soon as possible.
Best regards.
NJR Offline
Quarre,
be very careful with the products you use as some could react with the thin plastic windows, clouding them or making them brittle....a costly mistake.
Please use a product designed for the job and Ronovo does polish out scratches.
cheers and good luck.
rgds
