3 members (Hamwich, gomog, JohnHarris), 380 guests, and 83 robots.
Topics49,848
Posts837,406
DazMog, The Impaler, tlchzj79
Page 4 of 7 1 2 3 4 5 6 7
So that's a bit less than 1/2 litre. If I buy 2 litres of oil that should be enough.
Tim, what are you willing to risk with experimenting with the volume type of lubricant? Any thoughts on the potential ramifications if you get it wrong?
Having the drivetrain freeze and coming to an instant stop is a possibility.
Why isn't the factory addressing this?
1/2 US quart = 473.176473 milliliters
1/2 imperial quart = 568.26125 millilitres
Take your pick
smile
GreyGoose
I'm not experimenting with volume just trying to establish how much oil to buy. I will of course fill until it comes out of upper hole.
Tim
Originally Posted By TimG
GreyGoose
Tim
Tim, beware there are three holes in the BB, drain on the bottom, and Allen plug part way up and a vent plug on the right side. I mistakenly filled mine through the vent plug and put "too much" oil in it.
DOG is my Co-Pilot
Yes I have got that, fill to middle port with allen plug not the top port with orange plug
Tim.
Any update on the cause of your failure?
Was it I fact the BB or rear brake lockup or trans/ driveshaft?
DOG is my Co-Pilot
About 450 millilitre
It was the bevel box that failed. The car is at the dealer and the box has not yet been opened. They disconnected the drive shaft and drive belt. The bevel box is completely seized up and unable to turn.When removing the oil plug the liquid is full of ground up pieces of metal.
I don't know the total extent of the damage beyond the BB and afloat spot on the back tire. I do have concerns though. When it locked up the clutch would not disengage the transmission. Did it do damage there also? What about the engine going from running at highway RPM to immediate stop? Did that do damage?
I'm still waiting to see the proposed resolution from the dealer. Although this is fun vehicle to drive, my confidence in the safety of operating M3W is shaken. Only the perfect set of circumstances prohibited this from being catastrophic.
Thanks for your interest.
Intreresting that you say the clutch would not disengage the transmission. If the the BB is locked solid, which then stops the engine dead, pushing down on the clutch will not do anything will it? Did you try starting the engine again after the incident? If so was the clutch in or out?
