2 members (DCH, Image),
242
37
Topics49,844
Posts837,360
Posts: 106 Likes: 1
Posts: 106 Likes: 1 |
Last weekend I wanted to make a trip with my Morgan Roadster 3.7 on some passes. Unfortunately, on the very first pass (close to the top) I recognised cooling water to the windshield. I stopped immediately and then I saw that the cooling water splashing out of the pressure relief valve in the cap of the coolant tank. After the cooling water was a little cooler, it has finished to splash out. I had to refill 3 litres of water. I have discarded my original plan and drove back home. On the way home, the cooling water is not over cooked. Now of course I'm confused why this is happening, and whether it can happen again. My Morgan was last year for repairs in their workshop. Two cooling tubes had leaks. But sins then I drove 2000 kilometers without any problems.
What's also funny. The temperature gauge was at boiling never above the central display area. If the cooling water is leaking from the pressure relief valve, it ought to be hotter than normal, and the cooling water thermal display should get into the red zone. But it didn’t… Has anybody an idea?
Morgan Roadster 3.7
Posts: 1,711 Likes: 1
Posts: 1,711 Likes: 1 |
Not sure of my physics here, but doesn't water boil at a lower temperature the lower the pressure? How high were the passes you were driving over? High-altitude cooking is the opposite of pressure cooking in that the boiling point of water is lower at higher altitudes due to the decreased air pressure.
Graeme: 2011 +4
Posts: 1,947 |
Not sure of my physics here, but doesn't water boil at a lower temperature the lower the pressure? How high were the passes you were driving over? High-altitude cooking is the opposite of pressure cooking in that the boiling point of water is lower at higher altitudes due to the decreased air pressure. That's right, high altitude tea is nasty stuff!
Posts: 27,807 Likes: 749
Posts: 27,807 Likes: 749 |
Not sure of my physics here, but doesn't water boil at a lower temperature the lower the pressure? How high were the passes you were driving over? High-altitude cooking is the opposite of pressure cooking in that the boiling point of water is lower at higher altitudes due to the decreased air pressure. This should make no difference as the system is pressurised and therefore not affected by the atmosphric pressure. Perhaps the cap is faulty releasing the pressure too early and with the slightly lower atmospheric pressure vented. New caps are cheap and an easy fix.
Posts: 106 Likes: 1
The cooling system is a closed system. It doesn't matter how high you are. And I drove several times such high passes (2500 meters above sea level)...
Morgan Roadster 3.7
Posts: 4,896 |
Had you driven much since the workshop, is it possible they did not properly bleed the system and left an airlock. If you put the heater on as you had not used it in the summer due to being higher up, if the air lock was in the heater matrix this might have been the issue. Just a thought?
Adrian
Yes air would do it as it would expand rapidly & push up the pressure
Posts: 106 Likes: 1
Thank you for your hints but mentioned points I can exclude.The repair was in October last year. Since then I drove a lot also on cold days with heater on. I never had problems before.
Morgan Roadster 3.7
Posts: 456 |
Buy a new coolant cap and take it from there. A lot of the these plastic coolant caps should be treat as a service item.
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
Cap would be my first thoughts.
