9 members (TrickieDickie, Toshi, Arwyn Williams, Graham, G4FUJ, JMcL, RichardV6, MartinB60, BLUE+4, Ambrose2), 345 guests, and 71 robots.
Topics49,847
Posts837,392
DazMog, The Impaler, tlchzj79
Page 4 of 5 1 2 3 4 5
If my badge starts to peel I will remove the remainder and leave 'plain'.
Ian
Stop press.....just washed the motor and two years since the badge was replaced it has peeled. The round bit of the R has come out.
I will pick the remaining blue out later.
Ian
Aldermog 2009 Roadster.......Never peeled,
Jays. 2009 Roadster............never peeled, but then mine must have been the last month of the old style badge!
DD1961.....Collected Friday ...now two letters down
PeterG, 2013 3W...Never Peeled.
Wirewheel Sept 2011 Plus4 peeled. Replacement has not peeled
Wirewheel Sept 2011 peeled. Replacement did not peel.
Richard-Aus. July 1976...never peeled.
JohnV6 2006 Roadster, 97 +4, 94 4/4 noone of them peeled
Max5 2010 Roadster Sport …peeled
JB62 2012 4/4 badge peeled within 6 months. Replaced at annual service. So far so good
Porsche 981 Spyder
V8 Speedster ( 5 years)
4/4 Competition spec (5 years)
4/4 4str Kent ( 10 years)
Wirewheel Sept 2011 peeled. Replacement did not peel. Update badge peeled 26th June. Now plain.
Ian
Shiremog 2012 Roadster. Peeled within weeks. Stripped & painted to match body. So far...
3.7 Roadster
4" Ruston Procter SD Tractor
1905 Merryweather steam fire engine
Roger-Cheshire 2011 4/4 Sport. Rear badge replaced when I bought the car 18 months ago. Replacement not peeled but noticed badge on cowl has peeled in the "O" so suspect the original
Roger
The solution.....fit an earlier pre mid 2009 badge. A much nicer design than the modern wings, the enamel sticks and it's a straight replacement!
Jay - what's the recommend way of removing the existing badge without causing any damage?
Roger
I believe it screw on under the cowl. If you remove the grill it should be easy
On later Plus 4's you can get at it from inside the bonnet. It depends how high the radiator is. Note that the pre 09 badge comes flat and you will need to put some curve on it to match the cowl. Two small nuts are the fasteners.Something like 8mm or 10mm.
