6 members (RichardV6, MartinB60, Soleng, Paul F, waikiore, Hamwich), 127 guests, and 25 robots.
John V6 63
Luddite 55
My Goodwood Revival 2026
Clutch for a 1982 4/4
DVLA frustration.
Old Book
by Pundit - 21/09/26 01:39 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,940
Posts838,606
Areg Offline OP
I hope this is an exception.
My brakes would pull to the right as I applied them so I read all the posts here.
1)Checked and made sure there was no air in the lines.
2)Checked the run out on the disks.
3)Decided to swap the pads from right wheel to left, so looked at the M3 and came to the conclusion that I could remove and replace the pads with the wheels still on and have better access if I took out the fenders\mudguards.
Took the bolts holding the support bar from the tie rod to fender off and that support bar fell loosely. I looked at the nyloc nut and it was visually about a 1/4" loose.
Shook the tie rod and it was clearly moving. I tightened the bolt took the M3 for a road test and perfect. Also the wondering that I thought was the nature of the beast has gone.
This is concerning as to why the bolt was loose, hopefully no one else's is.
"Also the wondering that I thought was the nature of the beast has gone."
Sorry, I did not understand your meaning, could you enlarge please?
Of great interest to me, because my brakes are indeed pulling to the right, and getting worse, so am off to the garage to check my nylocs....
Maybe that's wandering Paul - just a thought.
Yes, like this, I think (lederhosen optional):
http://www.google.fr/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0CCgQtwIwAQ&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DSVcJIMhmGys&ei=3N6uU9m0NcyHPYP_gOAN&usg=AFQjCNGrDIMdQ_vCd4FXpvtLBB9gBh8HoA&sig2=CBrbDaCW1-oAgiQ-eswSzA&bvm=bv.69837884,d.ZWU
These bolts need to be tightened regularly. If a tie rod goes a little loose it would impact the toe of one wheel and this could then explain why your car was veering when braking?
Yes, it would. Sadly, having checked my nylocs, they are both tight, so this is not the cause for me. Onwards and upwards then..........
By the way, when bleeding brakes, does one start from the wheel furthest from the master cylinder or closest - it must be old age creeping on?
Peter, many thanks for bringing back memories from my youth, lederhosen and all.
If it's a US 4 wheel car, I always do R REAR, L REAR, R FRONT and finish with the L FRONT.
Short answer is yes, furthest to closest.
Good luck.
Dan
.....further east, just reading about it last week.
Ian
Areg Offline OP
Wondering as: do I go straight, do I go a little to the right or do I go to the left. To hell with it I will just go all over the place. smile
Or Wandering as 4/4sprotsfun clarified.
There was no excuse for the bolt to be that loose at an extremely low milage, someone screwed up somewhere.
PaulJ, I envy your Seven. Would love to own a 160\165 but not going to happen for USA.
Agh, yes, wandering, I understand now. doh hand built cars........
Depending on which State you are in, it is possible to get a Seven kit imported, as long as you source the engine in the States, I believe.
BTW, the little picture is not actually my car, it was chosen frm the standard list of avatars, I have a suspicion it is actually a Westfield! Mine is an all yellow CSR.
