10 members (BLUE+4, Craig Jezz, CooperMan, TeddyAds, GrumpyPa, Horror, +8Rich, Joske Vermeule, Dek, Gordon D),
213
61
Topics49,860
Posts837,526
Posts: 3,643 |
Hi Dave, looks a great deal on your battery. Regarding the wiper blades I believe the subject was covered earlier this year and the suggestion was that the blades could be sourced from a Land Rover dealer and the cut to fit. If you have a dealer close to you it my be best to take one along to ensure the attachment matches your Wiper arms.
Posts: 208 |
Great without bumpers
Alpine regards Morgan 4/4 Sport 2012 Mini Cooper S 2017 Morgan 4/4 70th Anniversary 2006-2015 prev
Posts: 27,813 Likes: 749
Posts: 27,813 Likes: 749 |
VW beetle blades also apparently work
Posts: 463 |
My quest to get the car on the road took a step backwards last Saturday, the man at the ministry (license office) was unable to recognize the Vin #, something to do with the number not being in the system. In the meantime I checked out brakes, lights etc, unfortunately the only item not working was the hazard warning lights and clock, checked the gomog Web site for direction, it pointed towards the fuse block, after much searching I eventually found it under the dash,the Web Page said check fuse #8 for post 93 +8 cars, on my fuse block the fuse was missing, bingo I've found the problem. WRONG I concluded that this slot wasn't used seeing that there was only one contact present. Back to the drawing board. While changing the battery last week I noticed a live wire off the isolation switch terminal, the wire had an inline 10amp fuse hidden between the battery and the bulkhead so I removed the battery and found the blown fuse. Luck at last. Hopefully I can get the Vin sorted tomorrow
Dave 98 +8 Corsa Red 74 MGB Red
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Good luck with the VIN Dave.
Richard 1976 4/4 4 Seater
Posts: 82 Likes: 3
Posts: 82 Likes: 3 |
Nice car Dave, there is always something to tax your brain on the Morgan, but there is always a big smile when you drive it. Happy Morganeering.
Colin. --------------
RX450 easier ezchair. 2004 Roadster.CM51ERS.
Posts: 463 |
Vin all sorted, time for our inaugural drive.
