4 members (ITP, High Hamster, Davetherave, MJF), 213 guests, and 106 robots.
+8Rich 79
Topics49,871
Posts837,684
Rudolf
Page 1 of 5 1 2 3 4 5
#211022 20/07/14 10:07 AM
Peter J Offline OP
Formerly known as Aldermog
I’ve talked enough here about audio in the Mog, now the project has started!
This is a short update, I’m taking photos as I go and will post a filly illustrated “How to Fit Audio in a 2009 Morgan” when it is all finished!
What am I fitting?
1. An Alpine CDE 136BT head unit with CD, DAB/FM Radio, full iPod connectivity, Bluetooth and hands free operation and remote control.
2. Pioneer 10cm dual cone speakers
3. The standard Morgan external FM aerial, all £8.00 worth plus DAB powered splitter.
The parts, including Dynamat (£150 for 36 sq feet…!!), will have cost me about £400.
So, what have I done so far?
1. Stripped out the carpet from the passenger footwell where I found all the audio wires neatly stuffed into the nearside speaker fitting. That is a big win as I wasn't looking forward to having to do all the wiring.
2. Fitted Dynamat Sound Insulation, so the Audio doesn’t have so much competition from the engine. There is an added heat reduction benefit. I’ve covered the floor, transmission tunnel, Bulkhead including above the passengers legs and the outside skin of the footwell. I've also replaced all the non stainless screws with stainless.
This is a fun job…if you like contorting yourself deep into places no head normally goes. stars
3. Built a proper wooden speaker box rather than use the thin sheet of aluminium Morgan provide as a speaker mount. The box is screwed to the ash frames and glued together. I've lined it with Dynamat and filled with acoustic fibre, so it has the best possible chance of providing uncoloured sound and reasonable bass. The speaker is a 10cm Pioneer unit, fitting a larger unit would mean cutting the standard mount and space is very limited.
4. Re-fitted the carpets and speaker grill. The speaker looks inconspicius!
5. Lined the inside of the passenger door with Dynamat.
What’s next?
1. Repeat the above for the driver’s side…even less space, so I’ve taken the steering wheel off.
2. Fit the aerial, that means drilling holes in Aldermog (gulp) nerd
3. Fit the radio and test.
4. Remove the seats and fit Dynamat on the floor and on the rear bulkhead behind the seats, remembering to leave access to the battery!
5. Line the parcel shelf, wheel arches and upper rear bulkhead.
6. Make a proper storage box under the parcel shelf as per DW's guide. thumbs
7. Re-fit the seats with hard wood spacers to raise them by 15mm.
I suspect I’ll need half a second box of Dynamat, so that makes about 27 sq feet of Dynamat and about 25kg weight. But I’ve got someone lined up to buy the unused material.
Results, so far.
1. The passenger side was noticeably cooler on over the “TOTH Weekend” and there is less noise coming through into the area.
2. The passenger door shuts with a “quality car thud”
Conclusion.
Fitting sound insulation is worth it, even without fitting a radio!!
More next Sunday!
That truly "sounds" like a promising agenda.
I would strongly recommend however that you also install a bass amplifier: it won't transform the Aldermog into a Boombox, but you will get a more defined sound.
Have a great day! I'm currently in Bristol having a Boom...Breakfast after 2 hours of driving in the [boring] motorway. The fun part should begin shortly...
Cheers,
Vladimir
vMog is a 2013 +4/ 4 seater, dark red with saddle brown trim, wooden dashboard and console.
Interesting project and read Peter.
Looking forward to the photos…..
Peter - a tip - when drilling for the aerial, drill a small diameter hole from the inside. This means you can be certain of where the wire will go and if you then cover the small hole outside with a piece of masking tape you can centre the larger drill bit easily and protect the surrounding paint!! -- I've done it a few times now on my two mogs and some others and the method works!!!!
Cheers!
Robbie
2021 Plus Four -- Helga
211-WX-1433
Peter J Offline OP
Vladimir
The head unit has provision to do so, but a descent bass speaker and amp will almost double the price!
Amp
Sub
I was somewhat taken aback at the prices!confused
If I go ahead I'll use the empty space in the footwell to make an enclosure/footrest, the sound can exit upwards and reflect off the underside of the scutle/bulkhead.
Also I'll need to run a seperate fused power line from the battery as a good sub needs its own 40amp fused spur....And a 700w bass amp uses all the power from the alternator, so you can't run it with the engine off for very long without risking a flat battery.
All in all I'm unconvinced it is worth it. But once it is all finished I may need one more than I think!
Well Peter, that keeps you pretty busy! Great project. Our Mog was delivered with aerial and 2 speakers in the back. I never had audio fitted, always thought that the noise of a 1990 CVH powered Morgan permitted no real audio experience. I think the more modern Morgans are quiter though. Or maybe I have to do a rethink...??!
Ruut Bianchi
Drive on the Wild Side
Vladimir
Amp
Sub
Peter, you could have taken a different route and purchased the Black Roadster at Williams, has all the gear and is sound insulated, reportedly can hear the music clearly at 80mph, with roof off but nothing else. innocent
Adrian
Black Rat
Black Rat
Perhaps someone would like to comment on the relative merits (or otherwise) of the Morgan exhaust sound versus Bruce Springsteen hide
Keith
2013 narrow bodied + 4 Ruby.
