1 members (CraigL), 253 guests, and 97 robots.
+8Rich 84
Topics49,860
Posts837,485
Jonny72
Page 3 of 7 1 2 3 4 5 6 7
Originally Posted By Shmee150
Last week I headed to Malvern to pick up my Morgan 3 Wheeler in time for some summer fun.
Nice Machines Shmee, I do like them both.
Well Done. thumbs
Past The City Limits
I too have straight through pipes, 98db @ 2/3 max rpm.
Not too loud but a hard edge to the sound.
A bit like James Blunt v Axle Rose.
Originally Posted By donaldosaurus
Schmee, you can have my straight pipes as a swap, I will even throw in some ear plugs.
I am up for a swap Donald if you are ( my unmodified pipes for your straights + removables )
Weird - mine's the same 98db on standard pipes.
Red Leader drive
Mine is 105 with dB killers
I wonder how the Brooklands compare to those.
2010 Morgan +4
2014 M3W Brooklands
To be raced
The MP12 is a formidable machine and the Mog is the perfect antidote in a country full of speed cameras. Have you bought it or is it on loan?
The Brooklands is very loud and bassy which is perfect for the type of car. Mind you it is even louder when one pipe falls off.
All down to how the measurement is made, what's around it and a heap more vague stuff that always has an impact. My stock pipes measured 104db @4000rpm at Brands Hatch, 99db @4000rpm at Castle Combe and I'll be able to tell you what they do at Goodwood in a couple of weeks. Guarantee it'll be different again, as noise measurement is kinda like that - way too sensitive to be consistent in my view. Bear in mind that a 3db increase represents approximately DOUBLE the 'noise' and then you'll appreciate the pot-luck we all take when sat in line for the infamous sound test before going on track.....
Bottom line is that the stock pipes are too quiet IMHO, so a market definitely exists for more sound (and to a certain extent, performance of course) via aftermarket pipes. MMC do a true Straight-through in chrome (U310021 / U310022 - £198.90 + vat each) or what they call 'Noisy', which have the main front baffle, but none of the weld-in circles-with-holes baffles anywhere else (U310019 / U310020 - £191.25 + vat each). I personally think the Noisy would be the best compromise, but a properly designed replacement with a true motorcycle-type absorption silencer under the heat shield (as I've droned on about at length before!), would I think be the best solution.
Black Rat
Black Rat
It won't be a true reading as the exhaust noise measuring device will be picking up the noise of the engine as well. The test should take place in an open space so as not to pick up any bounced sound. The exhaust measuring device is only really accurate on cars where the engine noise is shielded by the bodywork.
Keith
2013 narrow bodied + 4 Ruby.
