Topics49,843
Posts837,341
Posts: 368 Likes: 1
Posts: 368 Likes: 1 |
Hi all, Would someone who has the grease fitting mod for the first series compensator be so kind as to tell me the diameter of the hole and where the center of the hole would be located (X inches from seam Y, something like that). Also, does the compensator also need to be drilled and tapped or is there already a threaded hole with a plug in it?
Thanks, Roland
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
I'd suggest checking with the factory helpline first. Apparently some compensators can have the grease nipple mod and some can't.
My dealer was all set to carry out the mod then got a call to check some part numbers (not sure which). Still awaiting the go/no go from the factory.....
Red Leader
Posts: 1,947 |
Chris
Who is paying for the mod, you or MMC?
Tim
I'm assuming MMC but will clarify with my dealer if/when I get an answer as to whether it can be done.
Red Leader
Posts: 368 Likes: 1
Hi Atalante83,
That is exactly what I need.
Thank you very much for your time. Roland
