1 members (sprinty), 280 guests, and 58 robots.
Topics49,860
Posts837,486
Jonny72
#207356 29/06/14 09:04 PM
My doors squeak when motoring along through the country side
It seems to be coming from the catch area, rubber to metal, very annoying
Has any body had this problem, and how did you eliminate (did you change the rubbers on the catch, if so where did you buy them from)
Thanks chris
2 seater +4 1998
Chris, you don't say if you run with the side screens on or off. If it's with the screens on, it may be the lower rear padded part of the side screen rubbing on the rear three quarter bodywork panel behind the door. Mine does this. I use polish, the type that doesn't leave any white traces, on both the body panel and the black plastic of the side screen. If this works you may find it needs to be done at regular intervals, but it's worth it for the peace and quite!
Philip.
Drive on the Wild Side
Hi Chris
My 96 +8's doors used to squeak, I tried several things to stop it but no success, then I noticed that NeilM's Roadster had a small rubber seal that runs around the inside edge of the doors where it shuts against the body, my car did not. I am not sure when the factory started fitting them as standard, maybe your car does not have them? I purchased these from a main dealer, they were only about £4. They were easy to fit with a sticky backing and the squeaking stopped. Also stops the bottom door edge rubbing the paint.
Hope this helps. cheers
Adrian
AJSki2fly #211971 24/07/14 01:30 PM
Hi All
I have a 2014 Brooklands Roadster on which both doors squeak and creak like mad and they are fitted with the rubber edging. drives me mad when traveling slowly and in and around town
Any suggestions ?
Frank
Frank
1953 Jaguar XK120 DHC
Are the side screens on tightly?
Ian
Indeed they are cant be any tighter
Frank
Have you tried with the side screens off? It is they that will be making all the noise, even if fully tightened up.
Are the hinge bolts tight?
The side screen fixing screws mounting plates may be loose to the door.
See if the 3 screws on each need a small tweak.
Mark - No Longer driving
It might be the door hinge pins. My door pins are definitely worn. You can check by lifting the rear end of the door if you can feel movement then the pins are worn. Previously I took the pins out and rotated them 180 degrees which cured the problem for a while but its come back. I think the answer for me lies in new hinge pins.
Jeff
2009 Black & Tan +4
