4 members (GrumpyPa, Morganmike, bmgermany, Ian Wegg), 295 guests, and 94 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
Originally Posted By Malcolm T
Worrall's book says that the last Moss box car was R7494 and that the changeover was 1972 (Apr), (if that helps)
There is, as so often occurs at Morgan's, an overlap so that whereas the last Moss box car was indeed R7494 the first 4 speed Rover car was R7475. The ones in between can be either.
1972 4/4 2 Seater
There is, as so often occurs at Morgan's, an overlap so that whereas the last Moss box car was indeed R7494 the first 4 speed Rover car was R7475. The ones in between can be either. [/quote]
Don't quite understand that bolded statement tmg. Either R7494 was the last or it wasn't...if any were built subsequently as 'inbetweenies' the last number fitted with a Moss would have been the last, similarly if any had been fitted with the 4-speed Rover box then the first of those would have been the first ever (which I thought was the ex Jellyman/Chas Smith 'Flying Cowpat') It sounds like explaining the laws of cricket to an American. Please expand.
Colin Musgrove
BMW 750i V12 Alpina
Have you misread what I've put? R7475 is the first Rover box, R7494 is the last Moss box. Those in between can be either.
1972 4/4 2 Seater
Yes I did misinterpret what you put! blush I think, after being away from direct involvement with Morgans for a few years, I was so horrified by some of the threads in the 'Soapbox' forum that my old brain became a bit addled!
Colin.
Colin Musgrove
BMW 750i V12 Alpina
Perhaps it is easier to understand if put as follows:
Cars up until R7494 all used the Moss box, all cars from R7475 were 4 speed Rover cars. The ones in between can be either.
Surely the other way round?
Best Regards
Lang may yer lum reek
Should be:all cars up to and including R7474 were Moss box, all cars from R7495 were Rover, the ones in between can be either.
1972 4/4 2 Seater
Just for the record, and thanks for the responses, I'm absolutely clear now on the fact that the car I was interested in, was never a Moss Box car and therefore it doesn't hold the value I thought it might. I don't seem to be able to get away from the fact that I'm still drawn to Plus 8s, as I'm now chasing after a 3.9 car ;-)
You will not regret it.
Best Regards
There is definitely something about a Plus 8. I have had three of them. Certainly the 1971 Moss Box car was quickest but it was a bit challenging given its age and not all that comfortable with super sports buckets and side pipes. The other two are mid 80s cars with 5 speed boxes, very comfortable and easy to drive long distances. I guess as I get older my need for speed has lessened and I find I appreciate the creature comforts more . . .
Best of luck with the search.
Mark
1934 SS MX4
1938 Series 1 DHC
1951 Plus 4
2005 Roadster
