4 members (JohnHarris, DPEvans, gmcn, Julian BB), 307 guests, and 52 robots.
+8Rich 81
Topics49,859
Posts837,504
Jonny72
Great ideas (painting and adding fuses). Why didn't I think of that when I pulled my 4/4 Crossflow engine to replace the clutch a few years back. Next time . . .
Mark
1934 SS MX4
1938 Series 1 DHC
1951 Plus 4
2005 Roadster
Read T Offline OP
Awesome suggestion with the fuses! Not being too electrically inclined, how do I find out which amp fuse to use for each circuit?
1960 Morgan +4 4 seater
1997 Nissan 240sx S14
2011 Nissan 370Z
2009 Triumph Street Triple
The biggest thing with a crossflow 4/4 is to protect the feed from the starter relay/solenoid that runs across the car to the fuse box. Unfortunately I can't find my photos, but it is worth putting a 30 or 40 Amp fuse at the solenoid end - should stop any magic smoke getting out.
As for calculating fuse capacity for each circuit, there is plenty of info. on line. If your car is anything like my old '76 there are only 4 or 5 fuses in the car. A lot of circuits are not protected, for example, headlamp circuits.
Read T Offline OP
Had some buddies over to pull the engine/transmission. Took maybe 10 minutes.
[img]https://fbcdn-sphotos-b-a.akamaihd.net/h...147b21a8a3c5471[/img]
2011 Nissan 370Z
Looks like a job well done.
Read T Offline OP
2011 Nissan 370Z
Love the sanding work!!
Read T Offline OP
I hate the work of sanding though!
Engine is at Macy's Garage in OH being well taken care of.
2011 Nissan 370Z
Read T Offline OP
Finished sanding, then doused the bay in lacquer thinner, and now goes on the first few coats of Eastwood Rust Encapsulator.
[img]https://scontent-b-lga.xx.fbcdn.net/hpho...amp;oe=5469BB68[/img]
2011 Nissan 370Z
Looking good.
