10 members (TalkMorgan, hugo, RichB, Rex_tulips, Zach, RichardV6, RedThree, DaveK, howard, lez),
303
41
Topics48,362
Posts813,332
Members9,215
Posts: 1,299 |
 2013 M3W # 793 'Mosquito'
Posts: 57 |
To rid the car of all stale electricity
Posts: 14,976 Likes: 1
Posts: 14,976 Likes: 1 |
Wire colours will help as they should be to a standard.
Richard 1976 4/4 4 Seater
Posts: 1,562 |
At least one of them ( cant identify from the picture ) is a 12v aux output , already fused in the fusebox, and another is the heated seats. I identified them using a voltmeter, while pulling the marked up fuses.
Posts: 1,944 |
Seeker On my car the purple/white one is always live & fed from fuse 18 Intercom. It has male pins & strangely with engine off measures 17.4 volt. There is another black/orange female pins fed from fuse 4 Instrument panel, live with ignition on. A third one black/light blue female pins, live with ignition but did not find which fuse as did not want to take out fuses 3, 5, 6 & 11 as they are engine related & leave well alone. Its not fed by any of the others. Mine was built June 2013 & as we are talking Morgan current cars may be completely different.
Tim
Posts: 508 Likes: 1
Dreiradschubser Talk Morgan Regular
Posts: 508 Likes: 1 |
Posts: 54 |
Useful info, I want to wire my sat nav to the plug that operates through the ignition but I cannot find anywhere that sells the mating connector. I have tried Maplin and local auto shops but no joy, any idea who sells them.
Thanks ...
Posts: 1,015 Likes: 1
Posts: 1,015 Likes: 1 |
Thanks ... Try these folks - if they don't do it, then nobody will! AES
Posts: 1,944 |
Or cut the connector off & use bullet connectors.
Tim.
Posts: 14,009 |
Have you tried Vehicle Wiring Products? They normally have a wide range of connectors.
