7 members (Mark+4, Jonathan G, Montegue, Ian Wegg, John V6, BLUE+4, RichardV6), 221 guests, and 43 robots.
Topics49,846
Posts837,376
#215695 11/08/14 05:36 AM
Whilst attempting to track down the latest noise emanating from somewhere behind the dash of my M3W, I removed the fuse box cover and discovered three connectors, not connected to anything. Any ideas ? Immobilizer, intercom, heated seats ?
thinking thumbs cheers
2013 M3W # 793
'Mosquito'
To rid the car of all stale electricity
Wire colours will help as they should be to a standard.
At least one of them ( cant identify from the picture ) is a 12v aux output , already fused in the fusebox, and another is the heated seats. I identified them using a voltmeter, while pulling the marked up fuses.
Seeker
On my car the purple/white one is always live & fed from fuse 18 Intercom. It has male pins & strangely with engine off measures 17.4 volt. There is another black/orange female pins fed from fuse 4 Instrument panel, live with ignition on. A third one black/light blue female pins, live with ignition but did not find which fuse as did not want to take out fuses 3, 5, 6 & 11 as they are engine related & leave well alone. Its not fed by any of the others. Mine was built June 2013 & as we are talking Morgan current cars may be completely different.
Tim
Dreiradschubser
Dreiradschubser
Thanks Tim
Useful info, I want to wire my sat nav to the plug that operates through the ignition but I cannot find anywhere that sells the mating connector. I have tried Maplin and local auto shops but no joy, any idea who sells them.
Thanks ...
Thanks ...
Try these folks - if they don't do it, then nobody will!
AES
Or cut the connector off & use bullet connectors.
Tim.
Have you tried Vehicle Wiring Products? They normally have a wide range of connectors.
