0 members (),
230
40
Topics49,904
Posts838,083
Posts: 1,075 Likes: 1
Posts: 1,075 Likes: 1 |
In order to prevent the Perspex window being opened from outside, cut a piece of 2mm Perspex about 1cm wide and 13cm long. This can be slotted into the groove in front of the sliding window preventing it from being moved. I drilled a small hole in one end to take a loop of cable tie to facilitate easy removal.
Posts: 1,569 Likes: 12
Posts: 1,569 Likes: 12 |
Neat and simple solution John
Steve L.
1996 Plus 8 N22 MOG
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Good solution but a person set on getting in only has to unto the Tenax fastener behind the door and put their arm into the car from behind the window, it is easy to reach the door lock and open the door.
Good solution but a person set on getting in only has to unto the Tenax fastener behind the door and put their arm into the car from behind the window, it is easy to reach the door lock and open the door. you could put a Rotwieler inside the car to bite their hand off.
Good solution but a person set on getting in only has to unto the Tenax fastener behind the door and put their arm into the car from behind the window, it is easy to reach the door lock and open the door. you could put a Rotwieler inside the car to bite their hand off. Serious though, on my car the door cannot be opened if it is locked with the key, and the Tenax fastener is most covered by the side screen.
Posts: 519 |
Problem is, if they want to get in, they'll just cut through the roof with a knife..
My widow lock idea is to deter the casual thief. A determined thief can get into any car.
Posts: 7,363 |
I specified my Roadster without door handles and by accident, this seems to be a pretty effective way of stopping entry, if my experience with passengers is anything to go by!  Brian
Brian
1970 Morgan Plus 8 - Moss Box (Indigo Blue) 2014 Morgan SP1 (Rocket Red) 2015 Morgan Plus 8 (Rocket Blue)
Good solution but a person set on getting in only has to unto the Tenax fastener behind the door and put their arm into the car from behind the window, it is easy to reach the door lock and open the door. That's why I normally lock my doors (and glove box) with the key if I'm leaving it parked in public for any length of time Peter.
Steve L.
1996 Plus 8 N22 MOG
In order to prevent the Perspex window being opened from outside, cut a piece of 2mm Perspex about 1cm wide and 13cm long. This can be slotted into the groove in front of the sliding window preventing it from being moved. I drilled a small hole in one end to take a loop of cable tie to facilitate easy removal. That should read inches not centimeters.
