1 members (ChrisConvertible), 282 guests, and 40 robots.
+8Rich 97
Luddite 54
Topics49,904
Posts838,087
#218670 26/08/14 12:52 AM
Felix42 Offline OP
In order to prevent the Perspex window being opened from outside, cut a piece of 2mm Perspex about 1cm wide and 13cm long. This can be slotted into the groove in front of the sliding window preventing it from being moved. I drilled a small hole in one end to take a loop of cable tie to facilitate easy removal.
Felix42 #218678 26/08/14 07:08 AM
Neat and simple solution John
Steve L.
1996 Plus 8
N22 MOG
Felix42 #218684 26/08/14 07:45 AM
Formerly known as Aldermog
Good solution but a person set on getting in only has to unto the Tenax fastener behind the door and put their arm into the car from behind the window, it is easy to reach the door lock and open the door.
Peter J #218700 26/08/14 08:23 AM
Felix42 Offline OP
you could put a Rotwieler inside the car to bite their hand off.
Felix42 #218712 26/08/14 08:54 AM
Felix42 Offline OP
Serious though, on my car the door cannot be opened if it is locked with the key, and the Tenax fastener is most covered by the side screen.
Felix42 #218720 26/08/14 09:28 AM
Problem is, if they want to get in, they'll just cut through the roof with a knife..
Felix42 #218721 26/08/14 09:36 AM
Felix42 Offline OP
My widow lock idea is to deter the casual thief. A determined thief can get into any car.
Freddy #218722 26/08/14 09:38 AM
I specified my Roadster without door handles and by accident, this seems to be a pretty effective way of stopping entry, if my experience with passengers is anything to go by! laugh2
Brian
Brian
2014 Morgan SP1 (Rocket Red)
Peter J #218792 26/08/14 05:51 PM
That's why I normally lock my doors (and glove box) with the key if I'm leaving it parked in public for any length of time Peter.
Steve L.
1996 Plus 8
N22 MOG
Felix42 #218847 26/08/14 10:18 PM
Felix42 Offline OP
That should read inches not centimeters.
