1 members (BertL), 333 guests, and 26 robots.
+8Rich 86
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,360
#219543 30/08/14 09:29 AM
All. Have found the the stay connecting the RH wing to the top of the suspension has severed - by the looks of it some time ago... At this point have just removed it. In all honesty the security of the wing (vs LHS) does not seem affected - does this stay actually do much? Appreciated. Kevin
It's not an uncommon problem Kevin. The fracture is caused by high frequency vibrations from the chassis, suspension and wing.
Get it repaired (welded) or replaced asap otherwise you risk damage to the wing due to lack of support.
Personally, I'd go for welding as you'll be able to get it done quickly and you'll probably not have the problem of any mounting holes being miss-aligned with a new one. The cars are handbuilt and brackets such as these are often 'worked' to fit.
