1 members (mog38583), 227 guests, and 72 robots.
+8Rich 75
Topics49,861
Posts837,540
Jonny72
Page 2 of 4 1 2 3 4
Thanks again Geir, seems like a summer job. My car is on stands in a cold garage for the winter. I will report back...
Have a nice Christmas :santa2:
-99 4/4, 1.8 Zetec, Indigo Blue, 2-seat, Suplex RS
-04 Citroen Pluriel, 1.6 Sensodrive, Met Orange
Lecat #170517 11/12/13 08:57 PM
Also worth cleaning the sensor in the Mass Air Flow Sensor (switch cleaner again but be careful as it is very fine!)
Keith
Thanks Keith, is it the type with a very fine metal wire?
Gear,
What thickness of plate did you use. I'm an engineer who has access to machines so was going to make a plate for my 2001 4/4 Zetec. I can copy the shape when I take the part off the engine.
Thanks and regards
Phil
Regards
Phil
2001 4/4 Red
The ECU for the black top zetec has had a lot of criticism. Has anyone tried an alternative ECU such as Omex etc that can be programmed? But keeping the standard induction.
yes i have a Nodiz Pro
nodiz pro
Don't Worry, Be Happy
Morgan 4/4 1985 2,0 Zetec
BMW R1200 GS
Triumph TR140
Hi Phil
I used a beer can to make the plate.
4/4 2 seater 2001 model
Pic I hope
Some positive results finally smile
After fitting a restrictor plate with two 6 mm holes there were some improvements but not good enough. I then cleaned the ISCV connector and the 'throttle position sensor' connector with a de-oxidizer (and then a protecting electronics spray). Finally I made a ECU reset as described here: http://forums.focaljet.com/zetec-tuning/459693-ecu-reset.html - see 'iTrentz' post.
After fitting the restrictor plate the engine revs was pleasantly low when starting cold but it still kept revving after acceleration when warm. Sometimes it worked better though and that made me think of bad connections. After cleaning the connectors I did the ECU reset and after 10 minutes of idling the revs were down to 900 rpm.
I have done a few rather long stints to teach the ECU and it actually feels a lot better now. The revs falls in a reasonably normal fashion and it's getting better and better.
Hope this info can be helpful.
Regards
P.S. I learned from a Ford technician that the 'idle speed control valve' operates with a frequence of current 'on and offs'. The valve is kept in a 'neutral' position with a certain number of 'on/off's and is sensitive to voltage changes - bad connections will probably upset the whole system, including mixture, ignition and everything related to the engine management.
Rev hang, my old V6 Roadster suffered from that too
Page 2 of 4 1 2 3 4
