10 members (Steve3.9+8, Jon G4LJW, nickmog99, davewhite, Tom Sayles, JMcL, jbk, Hamwich, CRL, MATTMOG), 217 guests, and 120 robots.
+8Rich 78
Topics49,872
Posts837,687
Rudolf
#220645 05/09/14 12:53 PM
Ncik P Offline OP
Hi all,
I'm on the look out for my first Morgan and have decided that a +4 would suit my needs and pocket. I have looked at a few now and been surprised by the amount of bodywork corrosion, including reasonably recent cars (i.e. 2010). Is this normal with Morgan ownership, if so, how can it be prevented.
Thanks for the help.
Nick
Ncik P #220648 05/09/14 01:04 PM
dmh Offline
I might have been lucky - fourth Morgan and no corrosion!
Keep looking Nick - you will find a good example, particularly with Main Dealers.
Good Luck.
David H
Ncik P #220651 05/09/14 01:35 PM
Formerly known as Aldermog
Nick,
A good +4 is an excellent starting point!
But corrosion of any form shouldn't be an issue on anything after they introduced stainless steel bulkheads, rot proofed the ash coachwork replaced steel wings with thermoformed alloy and galvanised the chassis. these changes didn't arrive together but were in place by about 1998 - 1999.
Since then there have been detail improvements, but a 2010 car should be close to perfect, fully undersealed and as the exhaust is now stainless there isn't anything to corrode. Yes there may be a bit of surface rust on the suspension bits, brake drums, especially if it hasn't been used much.
Go to Morgan dealers and have a look at the cars they offer. Don't buy privately unless you are confident you knw as much as about a Morgan as the seller!
Good luck!
Ncik P #220659 05/09/14 02:40 PM
Nick,
I agree with Peter.
Allon White have an open Sat where you might see a few different cars
Ncik P #220663 05/09/14 03:07 PM
Hi Nick, welcome to the forum. I am surprised to hear of a 2010 example with corrosion, walk away, move on the the next one.
Ian
Ncik P #220664 05/09/14 03:12 PM
Hi Nick, welcome too....like the others I am surpised by your 2010 findings....keep hunting and the car will chose you!
Ncik P #220669 05/09/14 03:32 PM
Ncik P Offline OP
thanks for the responses, in fact I've visited Allon White where I test drove a 2006 +4 and I'm still trying to decide if it's the correct car for me. They also have a supercharged 2005 +4 and although I haven't driven this car, it's very tempting, although on the other hand I'm not convinced buying a highly modified example is a good idea.
thanks again
Nick
Ncik P #220686 05/09/14 05:39 PM
thanks again
Nick
When buying a car that is modified for performance it can make a big difference on insurance, statement of the obvious really but when I was looking I talked it through with the insurers and came to the conclusion that unmodified made it easier for me to justify the costs to myself doh
good luck with your search and enjoy the experience
Pete
Ncik P #220692 05/09/14 05:56 PM
thanks again
Nick
For that money I would buy a Roadster S1.
Ncik P #220694 05/09/14 06:03 PM
+1 on the Roadster.
As well as Allon white cast your net a bit further. Rutter isn't far away at Sawbridgeworth and there is always RT near Reading
