7 members (Graham, G4FUJ, RichardV6, sewin, Dinko, B3MOG, James B W, Strathaven),
244
Topics49,908
Posts838,114
Posts: 45 |
Silly question but how do you set the trip meter to zero.i have pressed it and it still shows the odometer reading.no info in the book.am I being dim.it must be simple.any help please.
2014 Morgan Ivory white 4/4
Posts: 5,468 Likes: 172
Posts: 5,468 Likes: 172 |
Long press to reset. As in several seconds I think.
Posts: 2,814 |
Hi Dishy, on my 2000reg 4/4 I just press the reset button momentarily to zero the trip. It usually jumps back to total mileage immediately afterwards. Like a lot of other Morganistas, I rely on the tripmeter for an indication when to refuel, the fuel guage itself being notoriously inaccurate. Gerry.
Gerry
Posts: 45 |
Thanks for the replies fellas.i will try again. I didn't realise until I saw some posts about the fuel gauge inaccuracies. A good reason to know how to use the trip meter. Why is the fuel gauge so quirky?
Posts: 1,418 |
I have to confess to taking almost 2 YEARS to find the trip meter button - when I caught my finger on it by accident ! On a 4/4 Sport (2009),you have to press the button briefly to change from total mileage to trip mileage, then press it upwards and hold for 4 or 5 seconds to zero it. I find that sometimes it jumps back to total mileage without zeroing but trying a second time usually works! There's also an instrument light dimmer - it only took me 3 months to find that one (on rhs under dash near drivers door. I found that this "dial" moved clockwise and anti-clockwise but seemed to actually do nothing. (I always fiddled with it during daylight hours !). Only when I had my first service did I mention it, to be told it dimmed the instruments : I twiddled the knob (  Gentlemen, please ) that evening and the instruments went dim, then bright again!!! Cheers
Jeremy
2009 4/4 Sport Green
And nothing else !
Posts: 526 |
Jeremy, you obviously have the deluxe version of instrument lighting adjustment - I didn't realise there was a bright setting, mine only does 'dim' and 'even dimmer' !
Pete
Posts: 45 |
Brilliant info.thanks a lot.yes I found the light dimmer and at first thought it was a radio volume switch.could not check as no radio fitted at the time. This info is not in the book.at least I could not see it.i will try the trip meter again tomorrow.all the best
Posts: 1,418 |
Jeremy, you obviously have the deluxe version of instrument lighting adjustment - I didn't realise there was a bright setting, mine only does 'dim' and 'even dimmer' !  Agreed Peter - I was being "generous" to the procedure. Perhaps that's why it's called a Dimmer switch  Cheers !
Jeremy
And nothing else !
Posts: 834 Likes: 28
Posts: 834 Likes: 28 |
The man who invented the Dashboard Rheostat is the same bloke who invented low energy light bulbs and modern toasters.
Any one ever found a use for instrument dimming in any car under any circumstances?
1993 T16 +4 Lancia Blue.
Posts: 3,643 |
Don't you never dim the living room lights with your early girlfriends. The dashboard dimmer is the same thing! Just ask JLT.
