8 members (Lance, M3WMW, SEG, cerealsurfer, +8Rich, Hamwich, stumog, Black Adder), 212 guests, and 48 robots.
+8Rich 99
John V6 57
Topics49,909
Posts838,126
#224517 25/09/14 09:33 PM
dishy Offline OP
Silly question but how do you set the trip meter to zero.i have pressed it and it still shows the odometer reading.no info in the book.am I being dim.it must be simple.any help please.
2014 Morgan Ivory white 4/4
dishy #224520 25/09/14 09:36 PM
Long press to reset. As in several seconds I think.
Costock, UK
Disco 5
dishy #224522 25/09/14 09:50 PM
Hi Dishy, on my 2000reg 4/4 I just press the reset button momentarily to zero the trip. It usually jumps back to total mileage immediately afterwards. Like a lot of other Morganistas, I rely on the tripmeter for an indication when to refuel, the fuel guage itself being notoriously inaccurate. Gerry.
Gerry
dishy #224527 25/09/14 10:07 PM
dishy Offline OP
Thanks for the replies fellas.i will try again. I didn't realise until I saw some posts about the fuel gauge inaccuracies. A good reason to know how to use the trip meter. Why is the fuel gauge so quirky?
dishy #224533 25/09/14 10:36 PM
I have to confess to taking almost 2 YEARS to find the trip meter button - when I caught my finger on it by accident !
On a 4/4 Sport (2009),you have to press the button briefly to change from total mileage to trip mileage, then press it upwards and hold for 4 or 5 seconds to zero it. I find that sometimes it jumps back to total mileage without zeroing but trying a second time usually works!
There's also an instrument light dimmer - it only took me 3 months to find that one (on rhs under dash near drivers door. I found that this "dial" moved clockwise and anti-clockwise but seemed to actually do nothing. (I always fiddled with it during daylight hours !). Only when I had my first service did I mention it, to be told it dimmed the instruments : I twiddled the knob ( nono Gentlemen, please ) that evening and the instruments went dim, then bright again!!!
Cheers
Jeremy
2009 4/4 Sport Green
And nothing else !
Jeremy, you obviously have the deluxe version of instrument lighting adjustment - I didn't realise there was a bright setting, mine only does 'dim' and 'even dimmer' !
Pete
dishy #224537 25/09/14 10:45 PM
dishy Offline OP
Brilliant info.thanks a lot.yes I found the light dimmer and at first thought it was a radio volume switch.could not check as no radio fitted at the time. This info is not in the book.at least I could not see it.i will try the trip meter again tomorrow.all the best
rofl Agreed Peter - I was being "generous" to the procedure. Perhaps that's why it's called a Dimmer switch getcoat
Cheers !
Jeremy
And nothing else !
dishy #224586 26/09/14 07:39 AM
jbk Offline
The man who invented the Dashboard Rheostat is the same bloke who invented low energy light bulbs and modern toasters.
Any one ever found a use for instrument dimming in any car under any circumstances?
1993 T16 +4 Lancia Blue.
dishy #224601 26/09/14 09:02 AM
Don't you never dim the living room lights with your early girlfriends.
The dashboard dimmer is the same thing! Just ask JLT.
Ian
