1 members (+8Rich), 330 guests, and 47 robots.
+8Rich 84
Topics49,860
Posts837,485
Jonny72
Page 4 of 4 1 2 3 4
titus #224783 27/09/14 07:23 AM
First thing I'd do is a full brake fluid flush it should be done every 2 years regardless of distance travelled
As to Aeroquip hoses - standard brake hoses are reinforced braided anyway, you just don't see any bling on the surface
People change hoses are convinced it made a massive difference, but that's more than likely to be the new brake fluid you're noticing!
Mark - No Longer driving
Jays #224796 27/09/14 09:28 AM
Black Rat
Black Rat
Originally Posted By Jays
My Tarox 6 pots certainly don't over brake my Roadster but give it a lot more feel and more progression as well.
So how much do Williams charge for the Tarox anchors..?
They used my car to develop the kit so I've no idea what their price will be. I'm sure Lawrie will be along soon to let you know!
That means a lot of money work
Keith
2013 narrow bodied + 4 Ruby.
titus #224801 27/09/14 09:53 AM
titus Offline OP
Brake fluid changed last year and checked by the garage and the fluid was okay, but will be changed when overhauled.
Never been convinced by the brake feel from new.
Yes, it will ultimately brake very well, but general reduction in forward motion seems to need more pressure than my '72 4/4 which was unassisted.
Titus
Titus
2007 +4 4 seater
2017 Mini Cooper
2007 VW Camper
1996 Honda TRX300
2012 Husqvarna 216
titus #224806 27/09/14 10:36 AM
This difference in feel between your old 72 4/4 (I owned a 72 4/4 for four or five years) and your current +4 could be due to the master cylinder bore size although there's not much you can do about.
Titus, can I suggest this: stick your head down into the footwell and depress the brake pedal. Try and determine how much 'free' movement there is before you meet pedal pressure. A lot of movement may mean poor adjustment.
I can't speak for your car, but Morgans generally have an adjustable pushrod with a clevis bracket and spilt pin that fastens the pushrod to the brake pedal. If you have excess movement and it needs adjustment, this is one possible area for a solution.
titus #224888 27/09/14 08:39 PM
Black Rat
Black Rat
I have a 2013 plus 4 and the brake pedal only moves about half an inch before becoming rock hard no sponginess at all. Brilliant brakes much more feel than my modern Ford which is really sensitive.
Keith
titus #225108 28/09/14 08:55 PM
titus Offline OP
That is encouraging Keith.
It all points to all or some of the above.
All being checked, adjusted and upgraded on Thursday.
Titus
Titus
2007 +4 4 seater
2017 Mini Cooper
2007 VW Camper
1996 Honda TRX300
2012 Husqvarna 216
titus #225213 29/09/14 02:02 PM
titus Offline OP
I have adjusted the rear self adjusters as in Gomog [url=http://www.gomog.com/allmorgan/APBRAKES.html][/url] Page 6.
It has taken the excess travel out of the pedal and feels much better.
The handbrake is also better.
Morgan assemble the handbrake first apparently, probably to stop it running down the hill between workshops scared This causes the handbrake to prevent the self adjusters from working.
When I released the cable and pumped the pedal the adjusters tightened up by 4 clicks.
Now for the fluid change, brake pads and Aeroquip hoses. smile
Titus
2007 +4 4 seater
2017 Mini Cooper
2007 VW Camper
1996 Honda TRX300
2012 Husqvarna 216
titus #225781 02/10/14 05:54 PM
titus Offline OP
All done.
Much better with more feel and better balance to the braking.
No problems found with front or rears.
Probably the most obvious change was the adjusting procedure of releasing the handbrake and pumping the foot brake.
Titus
Titus
2007 +4 4 seater
2017 Mini Cooper
2007 VW Camper
1996 Honda TRX300
2012 Husqvarna 216
titus #225955 03/10/14 05:24 PM
I'm pleased that you're sorted Titus.
Page 4 of 4 1 2 3 4
