Morgan Aero 8
2 members (RedThree, John V6), 276 guests, and 99 robots.
+8Rich 75
DaveW 52
Topics49,867
Posts837,614
Moggo
Hello Chris
Just rereading thread realised you hadn't answered my original question that might help in solving your leak. What did you mean by RMS?
Cheers
Philip
1985 Plus 8 four seater
Malone F1000 - track car
346VAB Offline OP
Apologies Philip I thought Deano had answered that question, yes it stands for rear main seal.
Where do the oil pipes connect with the block? is it possible that the leak from that would be in the bell housing?
Kind regards
Chris
Aero 8 Series 1
Audi TT Mk1
Chris, sorry since Deano put a ? mark, I was awaiting confirmation.
The two oils pipes from the filter enter the block below the exhaust manifold on left bank (view from inside car), and I would say around cylinder no.2.
I cannot conceive how a leak from these O rings would appear to come from RMS area, so almost certainly you have a different problem. The leak, when I had it on my car, was clearly from the left bank area.
Cheers
Philip
346VAB Offline OP
Hmm ok so if it did turn out to be the RMS then can the engine & box be split without removal?
Kind regards
Chris
Aero 8 Series 1
Audi TT Mk1
If it is the RMS then I am sorry to say its either an engine out or if you have a decent ramp, a gearbox out job.
I have to say though that in my experience RMS do not fail on modern engines.
Martin (Deano)
346VAB Offline OP
I'm doubting the RMS too but what else could it be given the location? Upper oil pan perhaps?
Kind regards
Chris
Aero 8 Series 1
Audi TT Mk1
Get it on a garage ramp and have an expert take a really close look would be my approach.
Martin (Deano)
Chris
Deano's suggestion is a good one. My car will be up on my four poster this week with bottom off (starter motor change). Any chance you could identify where oil is dripping down and I might be able to come up with couple of places from which oil leaking? Like Deano, I think RMS unlikely. Equally doubt it's seal on main bearing entry into gearbox.
Have you checked that fluid on ground is indeed engine oil and not a different fluid?
Cheers
Philip
346VAB Offline OP
As per the photo's I attached the oil is leaking from the bell housing where the engine meets the gearbox,I have checked the fluid and it does appear to be the engine oil. I will check again to be 100% sure.
Kind regards
Chris
Aero 8 Series 1
Audi TT Mk1
Sir S1'a'lot
Sir S1'a'lot
Sounds like RMS then
Unusual on a modern car....thought it was just Etypes
2002 Aero 8 S1
2023 Plus 4 (woman’s)
