+8Rich 95
Luddite 54
Topics49,904
Posts838,083
Lift the bonnet , lift the triangular inspection flap over the pedals, get a friend to fully depress the clutch pedal while you peek down the hole left by the inspection flap at the three hydraulic connections / 90 degree elbows on the inner wall.
At full clutch travel , my pedal was scraping against the brake hydraulic pipe and had worn through the plastic cover but not started on the inner yet.
With enough time and use I could imagine it wearing through causing total brake failure.
Temporary solution - slighty slacken the pipe nut and swivel the pipe away from the line of the pedal travel then tighten up again.
I am going to ask my dealer for something more permanent.
Thanks.
Thanks for the warning. All looks clear on my car.
Thanks for pointing nippymog,...will check mine thumbs
Cheers,
Georges
Thanks
I put it on the Check list
Nippy, any pictures?
2005 Roadster
2013 M3W
MOG South
I will do some pictures tomorrow - just been a fairly long run today and whacked out ! ( i.e. have hit the whisky )
