1 members (JMcL),
195
41
Topics49,904
Posts838,083
Posts: 1,562 |
Lift the bonnet , lift the triangular inspection flap over the pedals, get a friend to fully depress the clutch pedal while you peek down the hole left by the inspection flap at the three hydraulic connections / 90 degree elbows on the inner wall. At full clutch travel , my pedal was scraping against the brake hydraulic pipe and had worn through the plastic cover but not started on the inner yet.
With enough time and use I could imagine it wearing through causing total brake failure.
Temporary solution - slighty slacken the pipe nut and swivel the pipe away from the line of the pedal travel then tighten up again.
I am going to ask my dealer for something more permanent.
Posts: 522 Likes: 1
Posts: 522 Likes: 1 |
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
Thanks for the warning. All looks clear on my car.
Posts: 342 |
Thanks for pointing nippymog,...will check mine
Cheers, Georges
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
Thanks I put it on the Check list
Posts: 213 |
2005 Roadster 2013 M3W MOG South
Posts: 1,562 |
I will do some pictures tomorrow - just been a fairly long run today and whacked out ! ( i.e. have hit the whisky )
