2 members (SailingTom2, Morganmike), 305 guests, and 36 robots.
+8Rich 95
John V6 52
Posts838,013
rockabilly john
#227049 08/10/14 08:16 PM
lopesd Offline OP
I was out driving yesterday when there was a Big Bang from left side of car. I stopped and checked but saw nothing. Driving onwards the experience was horrible steering was awful brakes worked and off and the car had a habit of just pulling to the left.
I drove slowly home and jacked the car up. The left wheel now has about 2 inches of play. If I hold the bottom of the tired can push in and out about 2 inches. I see the brake disk also moves in and out with the wheel.
I'm assuming something with the hub has been damadged but has anyone any experience with this. What other issues could occur and mist importantly what kind of bill am I looking at
David
lopesd #227050 08/10/14 08:21 PM
Hi, sounds serious, but hard to tell. David, what model is the car?? and pictures of the issue would be most helpful.
Cheers,
Mark
1934 SS MX4
1938 Series 1 DHC
1951 Plus 4
2005 Roadster
lopesd #227056 08/10/14 08:31 PM
Sorry to hear of your failure David.
As Mark says a picture paints a thousand words - sounds like your suspension upright has maybe failed.
Hopefully someone in The Trade will have a better idea and respond on here.
I would try a pm to Chunky4/4 Racer from Williams on here as he repairs and tunes Morgans for a living.
Good Luck
lopesd #227058 08/10/14 08:32 PM
lopesd Offline OP
Plus 4 4 seater, 1996.
I haven't any pictures atm, having it towed to yardage tomorrow
lopesd #227076 08/10/14 09:02 PM
Sorry to hear, this could have ended far more seriously with that much of play in the wheel suddenly...
Hope you will share the failure diagnosis, so we can learn.
Keep it safe!
BertR
2025 Plus Six - 1909
2009 Roadster
1983 4/4 4str
lopesd #227077 08/10/14 09:02 PM
it sounds as if a wheel bearing has collapsed. Once the wheel is removed you should be able to locate the problem.
Cheshire_David #227080 08/10/14 09:08 PM
That's exactly what it sounds like. Happened to me once in a Capri.
1972 4/4 2 Seater
lopesd #227085 08/10/14 09:57 PM
Yep, wheel bearing collapse. If the stub axle had failed the car would not have been drivable.
lopesd #227110 09/10/14 01:26 AM
Bottom of the kingpin come undone maybe and lost rebound spring ?????
As another thought?
Mark - No Longer driving
lopesd #227135 09/10/14 08:46 AM
Drive on the Wild Side
If wheel bearing, then the cost will depend on whether the stub axle is damaged or not, form your description it sounds like a wheel bearing failure.
If stub axle is damaged then it's a new one, involving king pin strip down, if this the case then it might be worth thinking of replacing both at the same time with hardened chrome and new bushes, depending on how many miles the current ones have done and cash of course. You also need to inspect the brake disk carefully for damage, scoring. If you are lucky then you might get away with just a wheel bearing, I would replace the other side at the same time, I think a pair are about £60-70. cheers
Adrian
