10 members (Graham, G4FUJ, +8Rich, John V6, Luddite, Mats, ScotiaSteve, Image, Alan Patterson, Sir Percival, sewin),
244
62
Topics49,863
Posts837,561
Posts: 1,338 |
Yes i fill through the orange plug,the other seems to low,not enough oil.if the orange plug is wrong & its over filling the bb box,no problem,the extra oil will leak out from the breather.over filling is better than low oil,gears might get damaged
Posts: 90 |
Paul, I used the ventilation hole making the job without removing anything in 10 minutes. Just use a bottle with a plastic tube connected and pressure the oil in. Stig
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
Sounds like someone could invent a simple kit. Plastic bottle containing, or marked, for the correct volume of oil, and a plastic tube that fits to the bottle and fits, perhaps with an adapter plug, to the breather plug hole.
At a reasonable price I bet you would have a few takers.
Posts: 3,562 Likes: 12
Posts: 3,562 Likes: 12 |
Peter, I think you must be a man who can spot an opportunity at 100 paces? I use a pressurized bleeding kit for my brakes, I wonder if it would work with gear oil?
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
I have an oil syringe for doing just such a job, looks like a grease gun with a plastic tube sticking out the front and without the side leaver. Bought it in the late 70's, probably still available somewhere.
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
Oil hand pump Easy to use
Posts: 582 |
I'm using the same rig that Atalante shows but I had a major disaster when I blew off one of the hoses and ended up with RedLine all over the rear. I see the hose clamps, but I went one step further and drilled all the connections and used I/16" pins to keep the whole rig together--works a treat.
Posts: 786 Likes: 18
Posts: 786 Likes: 18 |
