0 members (),
373
88
Topics49,869
Posts837,666
Posts: 3,825 Likes: 69
Posts: 3,825 Likes: 69 |
Maybe explains why my dealer thought there may have been a remap.....
Posts: 5,210 |
So, mine is doing 55mph at 3000 revs in 4th. I didn't spec the axle so maybe they are just fitting the 4:1 now? Nick You luck man you have a 4.10 ring and pinion in your axle for free! Must have run out of the standard ones that say when they made that one!
Posts: 265 |
So, mine is doing 55mph at 3000 revs in 4th. I didn't spec the axle so maybe they are just fitting the 4:1 now? Nick I'm at 58mph at the same (Sat Nav speed = speedo). Not that I know what this means...
Looking for another Morgan!
Posts: 265 |
Same revs in 5th is 71 mph.
Posts: 486 |
So, mine is doing 55mph at 3000 revs in 4th. I didn't spec the axle so maybe they are just fitting the 4:1 now? Nick I'm at 58mph at the same (Sat Nav speed = speedo). Not that I know what this means... Basically speaking, you have the Aero Racing diff ratio in your Mog. On a stock engine you will have the feeling of a tuned engine as you will accelerate through the gears quicker. To understand more have a look here: http://www.performanceprobe.com/index2.php?redirect=http://www.performanceprobe.com/misc/index.php?do=calc&page=gearspeed Play with the ratios in the diff, you now have your gearbox ratios and the you have your tyre sizes. The transfer the info to when your driving to see how the car feels in the rev ranges and gears.
Cain
Wolf Cafe Racer 4/4 Sport
Posts: 265 |
Posts: 265 |
Measured MPH on GPS and used the Mazda ratios and final drive on the calculator is 3.92, which I'm guessing doesn't exist
Posts: 486 |
Measured MPH on GPS and used the Mazda ratios and final drive on the calculator is 3.92, which I'm guessing doesn't exist There is a 3:91 gear set, which would give the best of both worlds economy and sport. still a lucky man! Cain
Cain
Posts: 12,260 Likes: 319
Posts: 12,260 Likes: 319 |
Measured MPH on GPS and used the Mazda ratios and final drive on the calculator is 3.92, which I'm guessing doesn't exist There is a 3:91 gear set, which would give the best of both worlds economy and sport. still a lucky man! Cain 3.91, presumably that's the 47/13 arrangement? Will they fit the Salisbury axle, or are they just for the BTR, do you know?
Posts: 265 |
Measured MPH on GPS and used the Mazda ratios and final drive on the calculator is 3.92, which I'm guessing doesn't exist There is a 3:91 gear set, which would give the best of both worlds economy and sport. still a lucky man! Cain Nice one Cain! Cheers.
