Jay thanks for that, have now removed the offending object and visibility is vastly improved. CBY thanks also I will get some of that to remove the plinth.
If Morgan uses superglue (cyanoacrylates) nitromethane should work to desolve it. What is not used could provide an extra power boost, when dumped into fuel tank! Cheers, BertR
2025 Plus Six - 1909 2009 Roadster 1983 4/4 4str Board member Morgan Sports Car Club Holland ('21)
The Librands mirror on the rod is a good one. Together with the wing mirrors the rear view is fine. The only iffy thing is a couple of drips come through when the hood is up in heavy rain as the top fixing for it goes over the windscreen frame causing a very small point for water to get through. Even some self adhesive rubber along the hood where it meets the frame doesn't completely stop some drips. It's not a major issue but will be addressed at some stage.
Car manufacturers don't use super glue as it is not good with different rates of thermal expansion. It can therefore cause the windscreen to crack.
