3 members (sewin, OZ 4/4, +8Rich), 347 guests, and 40 robots.
John V6 66
DaveW 63
+8Rich 62
Dufty, Anted4, 4199, GOFFO1965, Joske Vermeule
9,212 Registered Users
First Morgan
195/60 R15 for 2018 Plus4
by Soleng - 24/07/25 05:32 PM
MulFab and Petrol Tanks
by Rovert - 24/07/25 09:51 AM
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Topics48,349
Posts813,101
Members9,212
aeroed, DJC, James Mc, JimWhin
Burgundymog #228768 16/10/14 10:03 AM
The mirror just slides upwards off a metal plinth which is the bit glued to the screen. Very easy to change to the smaller stainless version.
Burgundymog #228777 16/10/14 11:17 AM
CBY Offline
Regards
2005 PLUS 4
Burgundymog #228793 16/10/14 01:54 PM
Black Rat
Black Rat
Jay thanks for that, have now removed the offending object and visibility is vastly improved.
CBY thanks also I will get some of that to remove the plinth.
Keith
2013 narrow bodied + 4 Ruby.
Burgundymog #228862 16/10/14 07:55 PM
If Morgan uses superglue (cyanoacrylates) nitromethane should work to desolve it.
What is not used could provide an extra power boost, when dumped into fuel tank!
Cheers,
BertR
2025 Plus Six - 1909
2009 Roadster
1983 4/4 4str
Burgundymog #228891 16/10/14 09:22 PM
The Librands mirror on the rod is a good one.
Together with the wing mirrors the rear view is fine.
The only iffy thing is a couple of drips come through when the hood is up in heavy rain as the top fixing for it goes over the windscreen frame causing a very small point for water to get through.
Even some self adhesive rubber along the hood where it meets the frame doesn't completely stop some drips. It's not a major issue but will be addressed at some stage.
BertR #228938 17/10/14 07:59 AM
Cheers,
BertR
Car manufacturers don't use super glue as it is not good with different rates of thermal expansion. It can therefore cause the windscreen to crack.
2025 MG ZS EV aka Trigger
Burgundymog #228957 17/10/14 10:03 AM
I use this one, bought from H.o.E.
Mirror.
Burgundymog #229015 17/10/14 06:31 PM
Black Rat
Black Rat
Nice mirror, nice car !
Keith
Burgundymog #229110 18/10/14 09:31 AM
A bit of winter fettling Keith.
meabh #229184 18/10/14 06:23 PM
Black Rat
Black Rat
Indeed thumbs
Keith
