4 members (Rovert, yobtaf, John Winn, Bishmog), 302 guests, and 16 robots.
John V6 70
DaveW 67
+8Rich 66
9,208 Registered Users
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Topics48,341
Posts813,001
RedThree
#228649 15/10/14 06:41 PM
Black Rat
Black Rat
I want to move my interior mirror as it causes a blind spot on left handers. Does anyone know the best way to get off and will I be able to stick it back again lower down.
Keith
2013 narrow bodied + 4 Ruby.
Burgundymog #228657 15/10/14 06:58 PM
Because I wanted to learn how to fit the later screens I gave Shaun at Allon Whites a hand when I had a chipped screen changed in my 08 car. Shaun said they are a risk as sometimes the screen is damaged if your unlucky, he used a six inch length of wood, about 2"X1", held it as close to parallel to the glass as possible and gave it a sharp rap with a small hammer knocking the mounting block sideways. The residue from the adhesive pad was left on as we were changing the screen but I did ask and he said best scraped with a razor blade and then a solvent to finally clean up.
BR Colin
Burgundymog #228659 15/10/14 07:00 PM
RJW Offline
I tried dental floss first then resorted to very light gauge wire using a sawing motion to break the bond between the backing plate and the glass. It took a little effort to remove the residue of adhesive from the plate and glass. The mirror was then refitted lower down with Araldite.
Bob.
Burgundymog #228665 15/10/14 07:41 PM
That sounds a smarter way, that's how you remove PUR Bond windscreens.
BR Colin
Burgundymog #228671 15/10/14 07:54 PM
Black Rat
Black Rat
Hmm maybe I'll pop along to Autoglass.
Keith
Burgundymog #228742 16/10/14 07:38 AM
I cleaned mine up, after it fell off, by using nail varnish remover - with acetone. I also used some very fine sand paper before that!
A kind soul on TM suggested re-fixing it with sticky strips available from Ford. I didn't use those as the auto parts supplier had a windscreen mirror glue kit that was easy to use. The kit instructions included a useful suggestion to mark the point where it was to be glued with a crayon - but on the outside.
I was warned not to use Araldite as it was likely to crack the screen when it flexed.
I should also say that I bought a much smaller stainless steel mirror to replace the whopping great blind spot that was supplied when new.
Oct 13 build 4/4
Burgundymog #228743 16/10/14 08:01 AM
Black Rat
Black Rat
I wish mine would fall off
Keith
Burgundymog #228751 16/10/14 08:37 AM
I initially had to re-stick mine a few times and it never really held that well.
Somebody suggested cleaning first with acetone and it's held ever since.
Burgundymog #228759 16/10/14 08:58 AM
Have you already swapped the mirror for the smaller version from Librands?
If not, it halves the size of the mirror and still provides an excellent rear view. And it keeps the mirror high for those occasions when you have a case on the luggage rack.
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 5
Burgundymog #228765 16/10/14 09:27 AM
Black Rat
Black Rat
Paul, from your post I guess the mirror unclips, I could just take it off and rely on the door mirrors for lane blatting and pop it on for motorways.
Keith
