3 members (Taffmog, DaveW, Bishmog), 295 guests, and 100 robots.
+8Rich 76
Topics49,869
Posts837,665
Moggo
Sorry everyone I know that I am going to get slated for this but having problems with the old eyes in the open top at the moment and refuse to give up on my Morgan . Is there anyone out there that can fit air conditioning to a 4/4 Morgan year 2000 ? Thanks ( slightly embarrassed )
I have air con fitted to my Roadster and to be quite honest its a complete waste of money. Basically, all it is, is a cooling matrix in the air intake box under the bonnet. All the engine hot air gets sucked in as well and therefore the cool air comes through as luke warm.
Neil
Honda S2000
Lexus UX 250h
Toyota Auris Hybrid
Black Rat
Black Rat
My car had this fitted at the factory, believe me it's a waste of time it's not the same as in a tin top. I believe it's due to the narrow frontal area not enabling them to fit a large enough condenser.
Keith
2013 narrow bodied + 4 Ruby.
Thanks for the useful info , looks like a waste of money !
I purchased a 2013 Roadster demonstrator with 200 miles on the clock. The Factory fitted AC was a bonus since my wife was sold on the colour, not the spec. Anyway, initially I would have agreed with NeilM, on paper it's expensive and not effective. However, sometime later, I discover that there is a rotating dial inside the engine compartment which sets AC calibration. Turn it and the AC comes alive. I use it all the time when the hoods up, as it pumps out some chilled air. Ok, so the vents are still pointing at my trousers, but with a Morgan you have to live with the odd compromise.
J. Neil
Neil
If it is the 4/4 with the 1800 engine the same as my friend's '99 4/4 the air intake is much better isolated from the engine hot air as it has 2 separate intakes under the louvres.
On latter models the trick is to add foam or neoprene in such a way as to stop hot air from the engine bay entering the air intake.
We use our aircon often, obviously it is not terribly effective with the hood down but when the sun gets really too hot we put the hood up and the aircon on.
Borghi has fitted air conditioning to cars that did not have it so it is possible.
Formerly known as Aldermog
Whilst Caroline was driving the Plus 8 I was playing with the Aircon and heating.
The Plus 8 has a much more sophisticated heater box with both heat control and fan speed adjusted electrically. This means that both are fully adjustable across the range.
The radio has been pulled forward from the heater box: this has two big advantages. Firstly you can see the radio, secondly there are additional outlets, I think the box has three or 4 across the front of the heater box in addition to two on each side.
As a heater it is very powerful and the fan is almost silent.
The aircon is very effective at chilling your feet: with the hood up I suspect it would be good at keeping the cabin cool.
BUT it isn't as needed as one would be on the Roadster as the cockpit seems much better insulated from engine heat.
What worries me is that MMC are quite close to having a proper air blend heater/aircon = climate control as found in modern cars! On the +8 there is room, it would require re-locating the wiper motor and a couple of other small items and of course a new heater box unit...
Air con /Morgan
Oil/ Water
Pink
2011 4/4
I haven't stopped Laughing yet !
Aircon on a Morgan
Sorry
Wrap around shades on the eyes (like cyclists & runners use) and drive FASTER
Magwa
1950 Allis Chalmers B tractor
2000 Porsche boxster
2014 Skoda yeti 4x4 elegans
Is there any specialist eyewear that might help?
