Topics49,883
Posts837,828
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
In my 2005 Roadster the ignition cut-out button in mounted on the left side of the engine compartment attached to the bulkhead just behind the wiper motor and radiator reservoir. I believe it is reset just by pressing it. Yes that it where mine is. When I picked my car up the dealer went to great lengths to explain where it was and that it can activate sometimes from a jolt rather than a crash also that if the wipers stopped it is usually the connecting plug needs pushing together. That is also left side attached to bulkhead. Glad you got it going Felix
Posts: 17 |
I am back in the UK now after 3 weeks and 3 thousand miles in Spain, Portugal and France. The speedo showed 11574 miles as I drove out of garage where I keep the Roadster in Wales and 14574 as I drove it back in.
The ignition problem that you were all so helpful with was indeed the chip in the key. The issue is easy to identify now after the event, the chip had slipped out of the original key and I found it in the pocket of my shorts as I was unpacking the dirty washing.
timpot7 1 Morgan Roadster 2007 Toyota Prado 2009, VW Tiguan 2013, BMW GS 1200 2011, Harley FLD 2011
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
You are lucky you found it. Now a little dab of glue and Bob's your uncle  Glad to have been able to help.
Posts: 6,959 Likes: 117
Posts: 6,959 Likes: 117 |
Is anybody on here called Fanny........better not risk it
