Topics49,846
Posts837,383
Posts: 5,210 |
Earlier 4/4 were also slightly narrower across the body of the cockpit by I think c 5 inches. Wow! That would have been cosy! You'd have to choose your passenger carefully with that!
Posts: 28,894 Likes: 351
Posts: 28,894 Likes: 351 |
Yes, more or less. The actual body is the same width on all trads built today. The width of the mudguards is narrower because it is fitted with narrower wheels and tyres (like the 4/4). This makes the overall width of the car narrower. But not as narrow as earlier 4/4...
Earlier 4/4 were also slightly narrower across the body of the cockpit by I think c 5 inches. Wow! That would have been cosy! You'd have to choose your passenger carefully with that! Closer to 2" I think Roger, that was the approximate interior difference between my '76 4/4 and '97 +4. I understand 4 seaters may have had a little more interior width, particularly at the dashboard end...
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
Normaly it is the same interior just the narrow body With narrow tyres Without bumpers
Posts: 5,210 |
Earlier 4/4 were also slightly narrower across the body of the cockpit by I think c 5 inches. Wow! That would have been cosy! You'd have to choose your passenger carefully with that! Closer to 2" I think Roger, that was the approximate interior difference between my '76 4/4 and '97 +4. I understand 4 seaters may have had a little more interior width, particularly at the dashboard end... Still - every inch counts Graham! That's what I'm told by  !
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
So to clarify
The really early ones were really narrow except 4 seaters which were a bit less narrower than the really narrow ones and later ones were a bit wider but still called 'narrow' and then came along the Plus 4's which were wider than the later narrow ones but you can order the Plus 4 with a body which is narrow but not as narrow as the early really narrow ones.
Better not mention the widths of Roadsters, the one Plus 8 4 seater and Plus 8's !
Posts: 456 |
What is the difference in tyre sizes between 4/4 and +4 to justify the terms narrow and wide bodies?
Posts: 5,439 Likes: 131
Black Rat Charter Member
Posts: 5,439 Likes: 131 |
4/4 = 165x80x15 plus4 = 205x60/15 or 205x55x16 or 195x60x15. The 4/4Anniversary and the narrow bodied plus4 185x70x15
Still - every inch counts Graham! That's what I'm told by  !  I don't think any answer is required there Roger!!
Posts: 1,036 |
So to clarify
Better not mention the widths of Roadsters, the one Plus 8 4 seater and Plus 8's ! [quote=Eric Gill Sans] Stewart, don't start me off on Plus 8 widths. It's a pet topic of mine and I've a reputation as a pedant to maintain; it'll keep me going for hours!
